Anyone have a spare turbo piston laying around?
Posted: Mon May 02, 2005 8:41 pm
I want to do a displacement comparison of the stock versus turbo piston heads.
I am going to rebuild the engine again after the next rallycross and I want to modify the stock pistons for some lower compression so I don't have to rebuild the motor every 9 months.
I will stick the stock pistons in the milling machine and cut out/dish a little material out to lower the compression. I don't want to spend the money on exspensive pistons cause the price difference is a performance clutch.
