Gigantic hole in the side of my car....
Posted: Wed May 04, 2005 8:09 pm
by BAC5.2
So I decided to get savvy and try to fix the rust on the rear quarter panel of my car.
Upon removing the rust, I found that it went all the way through, so I just removed it and cut the metal around it.
Now, I have a few options.
1) I can figure out how to weld, and TRY to weld a plate over it.
2) I can just use straight up fiberglass and try to get it as smooth as possible.
3) I can pop-rivet a peice of aluminum over the hole and then fiberglass over that to smooth it all out at least a little.
What do you guys think? I am leaning towards #3, but let me hear what you guys have to say.
I must say, it was pretty fun to cut into the car like that. However scary it may have been :(
Phil
Posted: Wed May 04, 2005 8:31 pm
by AWD_addict
Do whatever you are most skilled/comfortable with. I sure wouldn't want to weld on my car without having a ton of practice first. 3 seems like the best option.
Posted: Wed May 04, 2005 8:51 pm
by gt2.5turbo
i would shoot for three... sounds like the one that would be the least likely to turn into a "i wish i would have done that first" sorta situation.
Posted: Wed May 04, 2005 9:34 pm
by dscoobydoo
it depends on how big the hole is. #1 is the best option for lonegevity. You can always take it to a body place and have them weld in a piece for not too much.
In #3, I would worry about forever seeing rivit pieces/marks
Posted: Wed May 04, 2005 9:44 pm
by QuickDrive
Duct Tape and Bondo baby :P
J/K
# 3 seems the best idea.
Posted: Wed May 04, 2005 10:24 pm
by evolutionmovement
I'd epoxy the alloy in. You won't get electrolytic corrosion that way either as the adhesive will keep the layers apart. Welding the metal is difficult if you don't know what you're doing as it's so thin.
Posted: Wed May 04, 2005 10:40 pm
by scottzg
4) find a new chassis? That sounds pretty eaten to me...
Posted: Wed May 04, 2005 11:59 pm
I'd actually braze rather than weld, I think... And brazing's pretty easy to do. You could grab some random sheetmetal from Crazy Ray's to practice on.
Posted: Thu May 05, 2005 12:17 am
Barely eaten at all - I imagine these are the rear quarters behind the wheels? These cars only have several small spots of problems (that every car gets). Doubt he'd find a much better chassis without going across country and then he'd have to deal with a likely ugly color and then the pain of switching everything around.
Southern Californians ... [shakes head] :lol:
Posted: Thu May 05, 2005 12:56 am
by scottzg
NORTHERN californian! :x
...but yeah, if a car has rust spots, we take pictures of it.
Posted: Thu May 05, 2005 1:28 am
by josh9227
its like this on both sides of mine and i need a new door i hate winter
Posted: Thu May 05, 2005 3:44 am
by corsair
I had the same as your problem Josh. An angle grinder, 3M bristle disk, bondo and a bodyshop later I had 6 months of a good looking fender. Now the rust is back, I think I'm going to buy my next car from Texas or California, or just something without 260,000 miles on it.
Posted: Thu May 05, 2005 5:13 am
Bondo is really a temporary repair. I hate the stuff because it's difficult to prepare the metal (which needs to be completely shiny to get rid of any trace of cancer - a harder thing to do than it sounds) and then the moisture gets under the Bondo and accelerates the rust. Even on healthy metal it sucks. In the old days they would smoothe out uneven panels with lead.
Posted: Mon May 09, 2005 6:34 am
by gnuman
evolutionmovement wrote:Bondo is really a temporary repair. I hate the stuff because it's difficult to prepare the metal (which needs to be completely shiny to get rid of any trace of cancer - a harder thing to do than it sounds) and then the moisture gets under the Bondo and accelerates the rust. Even on healthy metal it sucks. In the old days they would smoothe out uneven panels with lead.
In some places they still do, well, tin. . .
Actually, that was my 4). you can solder the new sheet into place, and if you use enough flux, it will be a clean, rust free job. Once you have it all smoothed out you need to coat it on both sides to prevent a reoccurance.
Posted: Mon May 09, 2005 6:53 am
by BAC5.2
I cut the metal and removed all rust, then used some bondo patch (stainless adheasive mesh) to cover the hole and offer me a little support to lay fiberglass.
I laid a bunch of fiberglass, smoothed it out, used some body filler to make it nice and smooth, and I just primered it today. I'll finish priming it tomorrow and paint it, then I'll be good to go.
Not entirely 100% you'll never know, but still pretty acceptable and I don't need to look at cancer on the side of my car.
Posted: Mon May 09, 2005 7:56 am
by isotopeman
Is it not possible to just buy another fender? I keep thinking that everything I've looked at on my wagon was bolted on, and the fender for the front quarter panel was 125$ new.
Posted: Mon May 09, 2005 1:55 pm
by BAC5.2
But this is a rear quarter panel.
Posted: Mon May 09, 2005 2:01 pm
by legacy92ej22t
Right on Phil. Man, that would be nerve racking to cut into your car.
Hope it turns out nice. :)
Posted: Mon May 09, 2005 2:06 pm
by BAC5.2
Hopefully it will. I'll just keep repairing body panels that need to be repaired until the whole car is fiberglass, lol.
It might not be perfect, but it'll be better to look at than rust :). I'll get pics later today.
Posted: Mon May 09, 2005 2:16 pm
by legacy92ej22t
Hehe, that'll be good weight reduction! You'll have the worlds only 2500 lb SS without giving up your AC and interior! :lol:
Posted: Mon May 09, 2005 10:14 pm
You could chop the whole fender flare out all together and replace it with glass at the joins.
The Lotus guy I know is helping me replace my crunched quarter with new metal. He has all the tools and everything - this guy rules! Then he tried to convince me the Lotus Europa he had in the garage was 'all me'.
Posted: Tue May 10, 2005 9:59 pm
by LaureltheQueen
My fender liner fell out a couple days ago going around a corner, and now I can see tiny bits of rust where screws were. ugh. This will be fun
Posted: Tue May 10, 2005 10:05 pm
by Tleg93
I had my body work done and the car repainted. The rust is already coming back and the dude left buffing patterns in my paint. :x
Posted: Tue May 10, 2005 10:27 pm
I'm thinking of using adhesive instead of welding on my new panel after talking to an auto body guy.
