Oil leak through threaded hole above head bolt
Posted: Thu May 05, 2005 3:13 am
So I have this oil leak and I finally think I've figured out where it is coming from.
Here is the link with a couple pictures of the location.
Here's the deal: I saw that little hole in the engine block there full of oil one day, so I sprayed down the engine with brake parts cleaner and got most of the oil you see there actually cleaned off. Then I drove the piss out of it on the way home from work one day and looked under the hood. That hole was full of oil again and the upper parts of the block had oilly colored fluid here and there. It really looks like it is coming out that hole when I am pushing the car.
Is there any reason other than head gaskets, that would explain fluid in that hole? I can't seem to find a leak on the turbo anywhere, and that is what is sitting behind and above that part of the engine.
-Ryan
edit: changed title to make it more appropriate
-Ryan
