04 pots front calipers for std diam/OEM discs
djorge
Post by djorge »
Is there any option? I almost bouth a set of those RS from subaruparts.com, but suddenly they were not anymore supplied; there use to be also some option from Perrin´s that either no longer exhist;
Post by BAC5.2 »
what are 04 pots?
OEM 4-pots from Subaru fit on stock 11.4" WRX rotors only.
THAWA
Post by THAWA »
04 = 4
def09
Post by def09 »
They are still available. Use part numbers 26292FE060 26292FE070. The new 06 WRX has the Red ones front and rear which will be available if the axle houseing mounting havent changed. I bet they will major $$$...$$$$.
Check on nasioc in the vendor group buy forum. Jamie is doing a group buy on the 4-pots.....and can get the rear 2-pots, but at 800 bucks....and a lot of work, I personally don't think it's worth it.
If I get them some day, I'll probably try and nab them from a junk yard.
