sloppy steering...
Posted: Tue May 10, 2005 5:19 am
by mhrallyteam
I have a slight dead spot in my steering, about an half inch. My ball joints and tie rod are ok, and my steering rack bushing too. Does anyone had to change a steering rack due to this.
Posted: Tue May 10, 2005 5:30 am
by BAC5.2
Get stiffer steering rack bushings.
Even new stock ones have a lot of play.
Posted: Tue May 10, 2005 5:51 am
by evolutionmovement
Yes, a bad rack will stick. The play is the bushings if the tie rods and ball joints are good.
Posted: Tue May 10, 2005 6:55 am
by scottzg
I bet the rack is walking in the little mount. Tighten the bolts if you can, or get new/upgraded bushings.
You can see this happening if you wiggle the wheel with someone under the rack.
Posted: Wed May 11, 2005 5:57 pm
by mhrallyteam
I already have upgraded mrt bushings, i guess i`ll replace both tie rod assy and ball joints. Maybe the control arm bushing are worn too, are those expensive
