Page 5 of 7
Posted: Fri Dec 08, 2006 6:57 pm
Here are pictures of the tapered rear springs.
http://www.main.experiencetherave.com:8 ... pring1.jpg
http://www.main.experiencetherave.com:8 ... pring2.jpg
I'm not sure I get your question, "how do you work out the tapered & non taperedness of the rear springs"
You should be able to look at the springs and see if they are tapered like in the picture, or are pretty much straight up and down.
Also, the top strut mount will be two pieces and look different then what's in the pictures if it's non-tapered.
Posted: Thu Jan 18, 2007 7:13 pm
by shemoves
Alright, I want to make sure I've got everything I need before I tackle this. Everything I've got is from an '02 WRX. Front struts (complete), rear struts (no tophats), Springs (4). An Upper Spring Perch is the same as a tophat, correct?
The list said I might need a washer between the rear top nut and top mount. Do I need the washer?
Posted: Mon Feb 12, 2007 2:09 am
by 93Leg-c
Just a quick question: In the compendium it lists the 2004 STi "Pink" springs -- are these referring to the JDM springs? I think so but I just wanted to verify. Thx!
Posted: Tue Feb 13, 2007 3:26 am
by shemoves
93Leg-c wrote:Just a quick question: In the compendium it lists the 2004 STi "Pink" springs -- are these referring to the JDM springs? I think so but I just wanted to verify. Thx!
Actually, I would imgaine that it refers to the ones Subaru makes (under the STi nomenclature) as a performance-oriented stock replacement for the USDM '04 STi. ('05+ STi had a slight change in the suspension requiring a different "STI pink" spring to be made.) They are pink and color, lower the STi about an inch, and stiffen it up a fair amount. They are considered to be an "STI" part rather than an "SPT" part. (SPT= Subaru Performance Tuning...the watered down US version of STi).
Posted: Sun Feb 25, 2007 8:09 pm
by n2x4
Noticed that the pic of a strut assembly was missing off the first page now. I happened to have a copy of it, so I'll post it. Maybe it'll make the thread less confusing for noobs.
Posted: Sun Feb 25, 2007 11:56 pm
by entirelyturbo
Good on ya. Thanks for that. I'm gonna edit the URL in the original post also to link to that picture.
Posted: Tue Feb 27, 2007 4:00 pm
by shemoves
Can anyone confirm is '02 WRX suspension into '92 SS needs a washer between the rear top nut and top mount?
Posted: Sat Mar 31, 2007 4:33 am
by bmxkelowna
new swaybar time!
trying to keep the bodyroll down for autox.
i have kyb agx front and rear and intrax springs.
the kyb's are set to 2/4 up front and 7/8 in the rear.
what should i do as far as sway bars? whiteline 22f and 18-22r? which ones work for my 92 turbo sedan?
Posted: Thu Apr 05, 2007 7:03 pm
by shemoves
bmxkelowna wrote:new swaybar time!
You want to be more stiff up front. Assuming lower is more stiff, I think I'd lower the rear to 5/6 to balance it out a bit, and have the sways set at 22f/20r. It also depends on how you like the car to drive though.
Posted: Wed Apr 11, 2007 1:42 pm
by DangerWagon
I think I have read right. let see. The Rear sway bars can be replaced with white line adjustable bars. When I buy those, do I order for 93-01 or 02-current. Or are they made to fit both?
Posted: Wed Apr 11, 2007 9:37 pm
by jamal
All non-sti Impreza rear bars have the same fitment and won't fit on a 1st gen legacy because of the spare tire well. I'll be trying to get one to fit fairly soon though.
Posted: Fri Apr 13, 2007 10:37 pm
by klaxed
a question about top hats. I am in the midst of buying parts for a suspension swap. am i right in the belief that if i make my suspension stiffer, i should get stiffer top hats or else my ride will bounce? if so what rear top hats will fit my car (i already have groupN's for the front)?
Posted: Fri Apr 13, 2007 11:09 pm
by jamal
93-01 Impreza tops are the same as yours.
Posted: Fri Apr 13, 2007 11:11 pm
by klaxed
jamal wrote:93-01 Impreza tops are the same as yours.
groupN ones or stock impreza tops? I want the tops to have the same stiffness all around.
Posted: Fri Apr 13, 2007 11:22 pm
by jamal
I mean they're the same shape and fitment, so group N impreza tops are the ones you want.
Posted: Fri Apr 13, 2007 11:26 pm
by klaxed
jamal wrote:I mean they're the same shape and fitment, so group N impreza tops are the ones you want.
I sort of knew that before. so where could I find some 93-01 impreza groupN rear top hats because i only see 2002-2006 impreza group N top hats on subarugenuineparts.com.
Posted: Sat Apr 14, 2007 3:09 am
by IronMonkeyL255
klaxed wrote:I sort of knew that before. so where could I find some 93-01 impreza groupN rear top hats because i only see 2002-2006 impreza group N top hats on subarugenuineparts.com.
Dale Teague at Boxer4Racing.com has them.
Posted: Fri Apr 20, 2007 5:22 am
by Bane
trying to reduce a little body roll...
already have full 02 wrx suspension, but after the past 100,000km car is feeling a little soft... anyone forsee any problem switching to 06 sti springs?
fitment issues anyone else tried this?
it's that or a set of 03 wrx eibach wagon springs.
first is nearly free $40, second is $150
Posted: Fri May 11, 2007 9:15 pm
by internetautomart
after having read through this several times.
I'm wondering if we can't put together a table that shows what parts from which cars fit ours.
something with the chassis codes across the top row and our chassis codes on the side going down. we would just mark an X if it fits or leave it blank if it doesn't, a question mark if it's unknown.
preferably with a chart of the chassis code abbreviations too.
Posted: Tue May 15, 2007 8:45 pm
by shemoves
Bane wrote:trying to reduce a little body roll...
I think the '04 STi springs are the only ones that will fit WRX struts...but I'm not sure that even those will. The softness you are feeling is likely due to mileage...these parts do wear out. If you like the way it felt when you first put it on, I'd just look for a newer replacement set. So you know, the Eibach springs and the STi springs are going to be very close in stiffness, and the Eibachs may even be a little more stiff than the stock STi springs.
Larger sway bars help quite a bit with body roll also.
Posted: Tue May 15, 2007 10:05 pm
by jamal
Putting stiffer springs on those struts is the last thing you want to do.
those springs won't work with your strut tops and upper perches either.
KYB struts on Legacy Turbo Wagon
Posted: Sat May 19, 2007 12:08 pm
by rnljarvis
Hi, I'm a infrequent lurker here but I thought I'd pass on a little first-hand info...
The KYB GR-2 23065 / 23066 (front) and the 23069 / 23070 (rear) struts fit just fine on the Legacy Turbo wagon. I was concerned that there was not a specific application for wagons listed in the KYB 2006 application guide.
After a few months, I'm pleased. The ride is controlled, not harsh. Hardcore performance guys may find fault or want more dampening with lower, firmer springs, but for my stock turbo wagon and everyday driving, I'm completely satisfied.
Hope this info helps someone...
Posted: Fri Jul 27, 2007 12:04 pm
by Bane
recently switched to GR-2's and i'm very happy with the results.
Group N Top Mounts
Posted: Wed Aug 22, 2007 6:03 pm
by siouxbe
Which Group N (STi) strut Top mounts will fit MY '91 Leg. N/A BF
wagon?
Posted: Wed Aug 22, 2007 6:39 pm
by spdracr
does your wagon have tapered springs in the rear? if they are tapered you'll need 04+ STi rear tophats. if they are not tapered than you can use anything 92-2004 for any model subaru as they are all the same in the rear.
