Best clutch for hard driving
Posted: Thu May 26, 2005 3:42 am
by 92BlackBeauty
What would anyone suggest for a good street/strip clutch?
I have already burned out one stock clutch in my 92 SS, and that really pissed me off.
I just recently pulled my seized engine in order to drop my new engine in, and upon looking at my clutch disc/flywheel, the disc is shiny on the outside and the flywheel is full of pressure cracks.
I must admit, I'm not one to baby this car, seeing as it is so fun to drive.
The clutch I put in must be able to withstand light track duty as well, and I do not want to run my stock clutch any more, as it only has 1000 kilometres on it and it is beginning to wear badly.
Has anyone else experienced this?
What is a good clutch for a decent price?
Posted: Thu May 26, 2005 5:05 am
by evolutionmovement
People run s few different ones and you can upgrade to WRX units if you get the flywheel form one. There should be plenty if you search.
What happened when you say the old engine seized? Is it rebuildable? Where are you located?
Posted: Thu May 26, 2005 9:30 pm
by ej22t
I had 2 clutch already on my 92 Turbo. The first one is CenterForce dualfiction, it let go after 80000Km , I use this car for TSD rally, Rally-X and one track race only, normal daily drive to work and shopping, paddle feels sporty and good respond. I also lighted the flywheele from Stock flywheel with this clutch.
Now I am using the ACT clutch with a new stock flywheel and new slave cylinder too. I was able to get the exidy clutch, but at the time I go order it have to takes about 3 weeks for the back order. so I took the ACT.
Both ACT and CenterForce are cost around $1200 for a set with out the flywheele.
Ben
Posted: Thu May 26, 2005 10:42 pm
by BAC5.2
I'd like to go to a twin plate after this clutch, but I can't see myself spending 1k on a clutch if I'm not making 400wheel.
I'm running an Exedy Stage1 with a LW Flywheel.
Posted: Fri May 27, 2005 2:53 am
by 92BlackBeauty
will the wrx clutch hold up to some abuse?
I've heard nothing but good things about the exedy stage 1.
This is really going to kill me, I just paid $600 for my stock clutch, and it's not completely worn yet. I just really don't want to have to do the clutch so soon after I drop my new engine in.
In response to what happened to the old engine, about 2 months ago my oil seal blew and leaked all over the gravel, and I made the stupid mistake of driving to town(I live on an acreage). By the time I heard the grinding it was too late. SEIZED
So I have an ej22t longblock on the way from B.C. any day now.
cost me $2400 canadian!!
Bottom line, are there any options under $500 canadian that will work for me here?
Posted: Fri May 27, 2005 3:26 am
by legacy92ej22t
I just installed a stage 1 SPEC clutch kit and so far so good.
The WRX kit runs around $350 USD and you need a WRX flywheel, or you can get the Legacy SS specific one for around $450 USD and keep the OEM flywheel.
Posted: Fri May 27, 2005 1:54 pm
by free5ty1e
http://www.horsepowerfreaks.com/price/S ... lutch_Kits
http://www.subarustore.com
I just got an ACT 13.9lb WRX flywheel and ACT organic clutch with HD pressure plate (and kit) for $650 total including shipping.
When I got the car I dropped a little over $1k to have the clutch replaced (and the guy promised to lighten and balance the flywheel too) but I had to bring the car back so many times before he actually replaced the clutch. And I discover now, he put in a used clutch (it only lasted a little over a year and a half with normal driving, and I do not wear clutches out fast). So, I'm doing it myself this time, and am quite happy to get away with a performance solution for that much...
Posted: Sat May 28, 2005 12:27 pm
by Tleg93
Damn, $650 seems like a big chunk of change to drop.
Posted: Tue May 31, 2005 11:57 pm
by 92BlackBeauty
Alright I can get away with using my stock pressure plate and other components for right now, its just that my flywheel is cracked all the way through. Can I use a wrx flywheel with my stock clutch?
Also, I have the option to get a centerforce dual friction for $600 CDN or an exedy stage 2 for $700 CDN
Which would you reccomend?
the exedy comes with the 25.2lb flywheel as well, so I might get it just for the deal.
Would anyone advise against lightening my flywheel since my car is awd? I heard this can lead to broken cv joints and differentials and such.
Posted: Wed Jun 01, 2005 2:16 am
by free5ty1e
I love the 13.9 lb ACT flywheel... much better than the stock 30 pounder. Feels fine to me.
Posted: Wed Jun 01, 2005 3:39 am
by 92BlackBeauty
did you notice any gains with the lightweight flywheel?
and also, can I use the wrx flywheel and my stock clutch, or do I have to replace the clutch and the flywheel to use the wrx?
Posted: Wed Jun 01, 2005 1:59 pm
by free5ty1e
the WRX flywheel/clutch have 3mm of extra contact surface diameter. So you have to get a WRX flywheel if you want to use a WRX clutch. And some places cross-reference Legacy clutches with WRX clutches, so you can't always just trust that a Legacy clutch is really a direct replacement without changing the flywheel.
With the lightweight flywheel, my car seems to pull harder at a lower boost than before. The ol' butt dyno is happy, I'll tell you that much. Can't wait until I feel confident enough to take it to the strip and see how she drags.
Once you hold both the stock flywheel and a lightened model in your hands and realize how freakin heavy 30 lbs is for a flywheel...
Posted: Thu Jun 02, 2005 3:40 am
by 92BlackBeauty
I take it your car is awd?
Yea really all I'm looking to do is satisfy the butt dyno lol :lol:
I have a stock flywheel on order right now though, and I'm going to wait until my clutch lets go befor replacing it with an exedy cerametallic 4 puck. Of course by this time I will be running a 16g with intercooler.
Posted: Thu Jun 02, 2005 11:56 am
by free5ty1e
Yes, my Leggy is AWD... I wanted a ceramic-based clutch but could not find one in a solid disc shape. Had to go with an organic clutch. Puck-shaped clutches engage quite harshly for an AWD drivetrain... the guy I spoke to on the phone at the Subaru Store heavily recommended against them, seen too many WRXs tear themselves up that way.
The ACT organic clutch with heavy-duty pressure plate engages QUICK. I don't want to feel what a puck clutch does to this car :)
I also hope to be running a 16g or 18g sometime soon... this little vf11 hybrid isn't doin as much as I want it to...
Posted: Fri Jun 03, 2005 12:26 am
by 92BlackBeauty
Have you done any launches over 6000rpm on the organic clutch?
Im curious as to how much quicker it engages comapred to stock. This is what's really killing my stock units, my launches.
Posted: Fri Jun 03, 2005 1:27 am
by free5ty1e
Why the Funk & Wagnalls are you launching at 6000RPM in an AWD vehicle?
Mine launches fine at 2500-3000 when I really want to take off quick. The turbo spools right up....
Posted: Mon Jun 06, 2005 1:19 am
by 92BlackBeauty
well here's one reason....I'm quite inexperienced with awd vehicles lol.
Truth be told, I mostly ride atv's and motorcycles in competition, but decided to take a break from that and take up track driving.
So really at 3500rpm my car will launch better that revving it out?
My car lags quite a bit on my launches.
Posted: Mon Jun 06, 2005 1:02 pm
by free5ty1e
Well, I'm not sure if the resulting time will be faster or not but it sure as hell will be easier on your driveline.
I find that launching around 3000-3500 rpm works quite nicely, especially if you feather the clutch just that little bit when you start to get the car moving and then drop the hammer. I think thats the key, gotta have the car NOT at a dead stop when you let go completely. That way, the wheels don't try to break loose and the tranny doesn't have to absorb those forces when it discovers that it has a bit of trouble breaking the tires loose :)
Not sure if I explained that correctly but hey it's early.
