16g making 365 horsepower?
Posted: Fri May 27, 2005 3:26 am
by 92BlackBeauty
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33742
Could someone tell me what kind of numbers they are making with the 16g and supporting mods? Anyone running one on a 92 SS?
with only an MBC, FCD, turbo back exhaust, and an intercooler is it possible to make the numbers posted in the link?
Posted: Fri May 27, 2005 3:43 am
by legacy92ej22t
I run one and no, you wont make those kind of numbers with the mods you listed.
The turbo is capable of producing the power but you'd need, SEM, probably DOHC heads, bigger injectors, probably forged pistons, medium to large FMIC, built tranny ect...
Posted: Fri May 27, 2005 4:30 am
by IronMonkeyL255
It's only really efficient up to about 18 PSI, or so I've been told.....
Posted: Fri May 27, 2005 5:19 am
by scottzg
You're gonna need race gas too.
Posted: Fri May 27, 2005 6:34 am
by azn2nr
1. that turbo wont fit your car.
2. that turbo is a tdo6, 16g which can make that much power but not with the mods you listed.
3. im running a tdo5 16g with exactly the mods you listed and ill be lucky to put down 210 whp
Posted: Fri May 27, 2005 1:34 pm
by free5ty1e
that turbo isn't the right 16G... clearly shows in the photo that it has a straight compressor inlet. We need a rather abrupt 90* angle there to work into our setup, or you make a lot more work for yourself trying to install it...
Look for the 16G from the WRX, it should have the 90* inlet...
Posted: Sun May 29, 2005 8:44 am
by BAC5.2
I'm on a TD05H-16G that's ported and polished and coated, and I make 214whp and 251lb-ft at 16psi.
Posted: Mon May 30, 2005 6:45 am
by 92BlackBeauty
See I'm just looking for a nice upgrade from stock lol :lol:
If i could be putting down 210-214whp that would be all I'm looking for.
so a td05 16g will fit my car with little/no modifying it?
i will be running it with a full 3"tbe, etc. to keep her flowing good.
Posted: Mon May 30, 2005 7:08 am
by J-MoNeY
92BlackBeauty wrote:See I'm just looking for a nice upgrade from stock lol :lol:
http://bbs.legacycentral.org/viewtopic. ... 95&start=0
http://bbs.legacycentral.org/viewtopic. ... 45&start=0
Do a search too.
