Air fuel gauge install
Posted: Mon May 30, 2005 8:46 pm
by TurboSubie
I have three wires, red,black and purple.
red-power(+ battery), black- ground, purple- front o2 sensor?? from downpipe. what wire do I tap into from the plug connector...it says I can't tap into the 02 sensor wires directly...also...I do use the o2 sensor coming from the downpipe right?
Posted: Tue May 31, 2005 2:07 am
by TurboSubie
no one know's?
Posted: Tue May 31, 2005 5:13 am
by 91White-T
If I remember its the red wire on the o2 harness. Check a wiring diagram to see which is the signal, pretty sure its red, but double check anyway. That should be it.
Posted: Tue May 31, 2005 6:40 am
by TurboSubie
should I use the o2 sensor coming off the downpipe??
Posted: Tue May 31, 2005 4:39 pm
by 91White-T
Yeah, thats the only one there is.
Posted: Tue May 31, 2005 8:44 pm
by TurboSubie
Thanks!
Posted: Wed Jun 01, 2005 8:44 pm
by TurboSubie
I am using an autometer air/fuel ratio gauge...I used the red wire on the 02 sensor for the signal wire...my gauge is showing two readings.. on is on stoich, and the other is on rich...why am I getting two readings? is the red wire the wrong one for the signal??
