heater motor not working
Posted: Fri Sep 26, 2003 10:56 pm
by su bar u guy
hey, my 91 heater motor won't work on any speed. So far I changed the speed control with one that I know works. Then I checked for power at the motor.( None) any thoughts?
Posted: Fri Sep 26, 2003 11:55 pm
by ciper
Have you checked the resistor inside the dash?
Posted: Sat Sep 27, 2003 12:05 am
by su bar u guy
No. Where in the dash is it located, and what does it look like?
Posted: Sat Sep 27, 2003 1:20 am
if you pull the glove box it's pretty much directly in front of you. It's inside the evaporator box.
Posted: Sat Sep 27, 2003 1:30 am
by su bar u guy
:) Thanks I'm gonna check it out right now.
Posted: Sat Sep 27, 2003 1:39 am
by su bar u guy
i tested the power supply plug to the relay and no power. Whats next?
Posted: Sun Sep 28, 2003 6:34 am
by 123c
You need part number 72024AA000... I replaced mine 2 weeks ago, and the part was $50 at the dealership...
Posted: Sun Sep 28, 2003 7:04 am
by su bar u guy
What is it and where is it located?
Posted: Sun Sep 28, 2003 7:07 am
by 123c
It's a resistor, and it's located behind the glove box. It's white, and it has some wires plugged into it. It takes less than 10 minutes to replace it.
Posted: Sun Sep 28, 2003 8:11 am
by su bar u guy
I tested each of the termonals inside that plug with the key on and the blower switch on and I don't have power in any of them. That's kinda why I ruled that resistor out. I checked the two fuses under the dash in the fuse box and there ok. I don't have power at the blower motor either. Any thoughts?
Posted: Mon Oct 06, 2003 9:32 pm
by su bar u guy
Just wondering does anyone alse have any ideas?
Posted: Mon Nov 03, 2003 12:01 am
by su bar u guy
Hey guys, I found my problem. It took a while, but it turned out to be a Relay on the drivers side above the fuse box.
Posted: Mon Nov 03, 2003 1:38 am
Oh, duh, the main fan relay... I shoulda thought of that. Sorry about that.
Nice work figuring it out. Did you have to get a new relay for lots of money from a dealer, or is there an aftermarket replacement?
Posted: Mon Nov 03, 2003 10:02 pm
by su bar u guy
I was lucky. I have a 90 LS wagon parts car. It had the same relay. :D
