92 Legacy Auto Transmission Problem
Posted: Sun Jun 26, 2005 6:35 pm
by beckery1
I have a 92 Legacy Automatic, Front Wheel Drive and with only 91,000 miles on it, is up to its third tranny. Each trans I've had installed has had the same problem. The shift from second to third is not crisp, it kind of hangs for a second or two and then goes into third and sometimes it doesn't feel like its going in all the way. I just had a new trans put in after the last one stopped working completely. It has this same shift problem between second and third. Otherwise the trans works perfectly. Since all the trannys I've put in this car have had the same problem, I'm wondering if maybe there's something external to the trans that could be causing this problem. I'm afraid that if I don't correct it, this trans will also fail. Any insight into this would be greatly appreciated.
Posted: Sun Jun 26, 2005 7:01 pm
by snowjob
I had the exact same thing happen to my first legacy, it was a fwd and I went thru 3 trannies too, mine hung the exact same way. I ended up selling it and getting a SS. I'm affraid I'm not much help, but at least you know you were not the only one.
Posted: Sun Jun 26, 2005 10:17 pm
The 2-3 shift is controlled by the brake band. It sounds like it needs to be adjusted (tightened slightly)
Here's adjustment procedures.
Posted: Mon Jun 27, 2005 5:03 pm
by beckery1
Thanks a lot, I'll give that a try.
