Adjusting pedals
Posted: Fri Jul 01, 2005 8:41 am
by scottzg
The distance between the pedals is great, but the brake pedal is much to much higher than the gas pedal. I noticed there is some adjustment nuts on the brake pedal, can i lower it with those without running around with my brakes engaged? Can i lower it a bit and take care of that slop at the top of the pedal travel at the same time? Has anyone bent the pedals or something to make for less of a gap?
The other thing that would be nice is if there was a little bit of space on the trans tunnel next to the gas pedal for me to stick part of my heel. I guess i'd have to bash it with my 5lb hammer... does anyone know if ill make myself a new contact point for the trans?
This car is really hard to heel toe.
Posted: Fri Jul 01, 2005 3:21 pm
by BAC5.2
You might have to start learning the twitch-foot style of heel-toe shifting, like I had to.
My feet were to big, so I brake with the left half of the ball of my foot, and blip the throttle with the right half of the ball of my foot. No heel involved.
It's easy because of a lightweight flywheel, I can just jab the gas and get the revs up, but it should work just fine with a stock flywheel.
Posted: Fri Jul 01, 2005 5:56 pm
by tris91ricer
Phil, our Scotty here is, uh. . . Well, he's a bigger boy, so he needs his space. Scott, punch a hole in that trans tunnel! That contact point alone has to be worth at LEAST another 5-10hp.
Posted: Fri Jul 01, 2005 7:31 pm
by scottzg
Haha, my feet are 11. Not THAT big.
Posted: Fri Jul 01, 2005 7:59 pm
by tris91ricer
Only 11? Suddenly I feel so validated, walking in my size 10s.
I have tiny feet.
Posted: Fri Jul 01, 2005 8:36 pm
by THAWA
You think it's hard with 11's :\
I find that if I pull my toes real high up on the brake pedal, almost touching the arm, I can shove the heel in there.
Posted: Sat Jul 02, 2005 12:27 am
by IronMonkeyL255
I wear 11 1/2s.....
All cars have the brake higher than the gas. Sorta annoying if you ask me.
Posted: Sat Jul 02, 2005 6:04 am
You can adjust the nut that the brake light sensor goes into, as it's what determines pedal height. However you'll then have to adjust the rod going to the booster to compensate for what you did.
I basically did this when I did my AWD swap and swapped pedals. I put the pedals where I liked them, and then adjusted everything.
Posted: Sat Jul 02, 2005 7:15 am
by scottzg
Legacy777 wrote:You can adjust the nut that the brake light sensor goes into, as it's what determines pedal height. However you'll then have to adjust the rod going to the booster to compensate for what you did.
excellent! I'm gonna do this too.
Anyone know how much space i can bash into the trans tunnel?
Posted: Sat Jul 02, 2005 3:01 pm
by evolutionmovement
You could get one of those alloy pedal covers to get the gas closer to the brake also. I used a set to close the lateral distance between the pedals so I could heel and toe easy (in actuality using the sides of my foot for each pedal). I have size 11s.
Posted: Sun Jul 03, 2005 1:23 am
by THAWA
Those pedals look like ass though.
Posted: Sun Jul 03, 2005 2:12 am
by 0perose
size 12 baby!
Posted: Sun Jul 03, 2005 6:09 am
Yeah, 'cause those tiny rubber pads look so sweet.
Posted: Sun Jul 03, 2005 7:37 pm
by IronMonkeyL255
I need to get some WRX pedals.......
Posted: Sat Jul 16, 2005 2:39 am
by THAWA
Posted: Sat Jul 16, 2005 6:42 am
by BAC5.2
I wear an 11.5 and do it the same way Steve does. Use either side of my foot.
Brake higher, when using this method, is beneficial. Just push as much brake as you need and pivot down for gas. Easy.
Posted: Sat Jul 16, 2005 6:48 am
by scottzg
Since this thread has come back to life, i figure ill mention that i have had better luck just using the tip of my toe to blip the throttle. I haven't bothered to adjust my pedals yet, so i have to settle through that bit of slop at the top, making it impractical when i dont need to brake much.
Posted: Sat Jul 16, 2005 5:51 pm
Hm, my brakes don't really start to do much until the gas and brake are near level.
Hmmm....
Posted: Sun Jul 17, 2005 7:37 pm
by fireytom
Wow I think I may be the biggest and youngest guy on this forum
. I'm 17 but I'm 6'6" with a size 15. It's a bit of a PIA to drive my BC, but i think it's worth it.
Posted: Sun Jul 17, 2005 8:28 pm
by snowjob
Weighing in with size 13s, I have problems with my foot hitting the foot support on the left when I'm clutching
Posted: Tue Jul 26, 2005 7:41 pm
by eastbaysubaru
I've also got 13's and they're wide bitches to boot. I'm just starting to figure out how to move my feet like that, but it's gonna be a long road
I think having some sort of driving shoe would help a great deal because they've typically got a lot less material surrounding your foot.
-Brian
Posted: Tue Nov 08, 2005 9:50 pm
by Thor
The leggy is my first sedan, but its an auto. I heal-toe in size 15's in my GMC Sierra.
