How to varify it......?
Posted: Mon Jul 04, 2005 12:36 am
by ej22t
Hi People, got an questions again and hope you guys could help me out.....
just has a chance to get the whole rear suspension with the rear crossmember with the lateral links. But the problem is I don't know its from GC style Impreza or newer model GD Impreza.
I know they looks similar but the GD 4dr should be longer then the GC.
I would like to put it to my 92 turbo with the new C shape end link but I have to make sure it will fits before I put this on.
Could anyone knows how to make sure it or what will be the lenght of both?
Thanks for your help and input...
Ben
Posted: Mon Jul 04, 2005 12:45 am
by jamal
GD sedans have longer lateral links, and wagons are the same length as the GC and BC.
*I think*
Why can't you find out what car they're from?
I'm in the process of doing the same thing, and I got my lateral links from a 99 impreza on nasioc. I think I'm going to have to cut the bolt off the inside to get it off, though.
Posted: Mon Jul 04, 2005 4:00 am
by ej22t
Its hard to varify because the rear crossmember is already off the car and its hang on the shop....
Are there are any other way to get vaify it?
Thanks for help
Ben
Posted: Mon Jul 04, 2005 5:17 am
by IronMonkeyL255
And the shop doesn't know...?
Posted: Mon Jul 04, 2005 5:28 am
by ej22t
Well, they said its for WRX, but they don't even what year of WRX since I ask for 2.5RS or the new WRX but they just said its from WRX ...... thats why I have to varify by myself.
Ben (-n-)
Posted: Mon Jul 04, 2005 11:34 pm
by jamal
Well, since the WRX didn't come out in North America until 02 as a GD, I'm guessing they'll be too long.
Posted: Tue Jul 05, 2005 3:45 am
Just get it. If you have to get the shorter lateral links.....who cares....shouldn't cost a lot for a junkyard set.
and yes, only the GD sedans had the longer links. The wagons are the same as all the older ones.
Posted: Tue Jul 05, 2005 9:51 am
by LaureltheQueen
*verify
Posted: Tue Jul 05, 2005 6:07 pm
by scuzzy
sounds like redneck slang
"y'all wanna varify that fer me?"
Posted: Tue Jul 05, 2005 7:32 pm
by ej22t
Hi People, thanks for all the input, I finally have time to measure the lenght on both my car and the to-be install rear crossmember and from bolt center end to end. Both of them are same lenght so I assume it will be the same one I want....
Will talk some pics after install with Revlab rear crossmember centering spacer and endlink.
http://www.toronto-subaru-club.com/cgi-bin....;hl=bsc
Ben
Posted: Tue Jul 05, 2005 9:49 pm
by jamal
What's a Revlab rear crossmember centering spacer? I don't see it on their site.
Posted: Wed Jul 06, 2005 1:00 am
by THAWA
The easiest way to tell is to look at the part right behind the diff. If it can accept a lower arm bar it's from a first gen, if it can't it's from a second gen.
