odd transmission leak on my '95wagon
Posted: Sat Jul 16, 2005 7:10 pm
on friday i was traveling on I-94 going about 80mph in my 95 L wagon. had to get onto an exit quickly and slow down VERY rapidly. as i stopped there was a large cloud of smoke out of the underside. not coolant. and quickly dissapated. i thought it may have been the brakes.
when i checked the passenger side of the trans was covered in trans fluid w/a small drop (about 2") on the ground.
moved the car. no more drips. checked the fluid in park while it was idling. it was full and had good color.
cant tell where it came from. possibly one of the two hoses up there on the pass side of the trans?
the last time the trans was filled was at least 1 1/2 years ago. so if it was overfilled you would think it would have blown something ouyt along time ago.
the AT temp light never came on. and after the initial leak none has leaked since. and i have driven about 300 miles since the initial leak and what did leak out has been cooked dry. and the car drives and shifts up and down just fine.
help.
help.
