interesting note after HKS turbo timer instal
Posted: Thu Jul 28, 2005 12:31 pm
As noted in many posts this is a very simple instal
The only wires from the TT
I used are:
the black (ground),
the red (always hot)
and the green (to the ignition switch "run" wire)
I used the run wire at the main ignition switch connector.
The blue wire I did not use (it normally runs to the acc. position )
When the TT is engaged both cooling fans operate for the
duration of the timer.
A nice feature I deem as I have a
NA rad in my turbo wagon and thus no
turbo expansion tank .
I used are:
the black (ground),
