Page 1 of 2
Pics of my RS-RA engine
Posted: Mon Aug 01, 2005 12:35 am
by napphappy
Pics of before and after install.
http://www.thawa.net/gallery/My-RS-RA
Posted: Mon Aug 01, 2005 1:04 am
by snowjob
DRool, That is sooo clean, where did you get it??? I'm lovin it.
Posted: Mon Aug 01, 2005 1:13 pm
by irishsetter
Very nice.
Posted: Mon Aug 01, 2005 5:24 pm
by napphappy
I got the engine from Rising Sun Engines. The are in Chico CA.
Nice guys to deal with. The engine came with ECU, cut harness(mostly there though), intake w/airbox, all engine related sensors including MAF, ignitor ect. Also came with AWIC, pump and heatexchanger
I took the only RA, Sorry
Posted: Mon Aug 01, 2005 8:59 pm
by IronMonkeyL255
Talk about a sleeper.....
Posted: Tue Aug 02, 2005 12:16 am
by THAWA
Very cool, Is that the AC compressor it came with?
Posted: Tue Aug 02, 2005 1:05 am
by douglas vincent
Are you happy with the AWIC effeciency? Have you checked the temp of the water before and after boost? What boost levels are you running?
I ask this cause I am not happy with mine but hope you are getting better results than me.
Posted: Tue Aug 02, 2005 1:16 am
by napphappy
THAWA wrote:Very cool, Is that the AC compressor it came with?
The pics before intallation show what it came with. I used the one originally on my car(134A)
Posted: Tue Aug 02, 2005 1:28 am
by napphappy
douglas vincent wrote:Are you happy with the AWIC effeciency? Have you checked the temp of the water before and after boost? What boost levels are you running?
I am still doing research with the AWIC. The pump is decent but the heat x-changer is not as big as I would like. its about a 1/3 the size of my radiator.
I am running about 15psi. I havent gotten any imperical data yet, but after a few High speed pulls the water was warm(not hot).
I want to install some thermocouples soon, to measure both intake air temp and AWIC water temp.
Posted: Tue Aug 02, 2005 1:45 am
by THAWA
15 psi on the VF8?
Posted: Tue Aug 02, 2005 1:50 am
by napphappy
THAWA wrote:15 psi on the VF8?
YES?
Whats your point?
Posted: Tue Aug 02, 2005 2:15 am
by snowjob
I'm pulling the same, they work very well at 15
Posted: Tue Aug 02, 2005 2:18 am
by THAWA
My point was to clarify which turbo you were using.
Posted: Tue Aug 02, 2005 2:19 am
by douglas vincent
naphappy, meet THAWA. THAWA, meet naphappy.
I had a small heat exchanger which didn't do squat, especially in traffic and at the dragstrip, where it would get hot.
So I upgraded to an AC radiator but it is maybe a 15% increase over the old small one because the tubing is soooooooo tiny barely any water gets through. It suffers a very very narrow urethra.
So now I am looking for an actual radiator or giant tranny cooler.
I also hooked up my two electric fans so they are on when the AWIC pump is on.
Posted: Tue Aug 02, 2005 2:28 am
by THAWA
shouldn't the AWIC pump be on all the time?
Posted: Tue Aug 02, 2005 2:33 am
by douglas vincent
Probably, but in my case, no.
Since I can go forever without hitting boost, I don't need it on. But if I want boost, I wired my SC into the AWIC switch so that I HAVE to have the AWIC on if I want the supercharger to turn on. Kinda of a safety thing.
Posted: Tue Aug 02, 2005 3:29 am
by THAWA
Hmm, you should try it the other way with the pump on all the time. That should theoretically allow you to remove the heat while you're not on boost right?
Posted: Tue Aug 02, 2005 3:41 am
Yeah, or at least make it so you run the AWIC pump and fans for a minute or so after boosting. You don't want to let the top-mount heat exchanger get heat soaked or anything.
Posted: Tue Aug 02, 2005 3:42 am
by douglas vincent
Oh I can do that, I just switch off the SC with its own dedicated switch. But if I am driving down to the local supermarket, I don't need boost, much less cooling.
Like I said, its mainly wired that way so I don't go on boost WITHOUT making sure the AWIC is working.
Posted: Tue Aug 02, 2005 5:56 am
by napphappy
The factory setup runs the pump @ 28watts normally. When the throttle is opened 80% or more the pump is bumped up to 50watts.
I didnt have the dropping resistor and such so mine is just full power all the time. I also have the radiator fan on that side running all the time.
Posted: Tue Aug 02, 2005 7:20 am
by georryan
Rising Sun motors huh? The place I got my GL10 motor from, here in Sacramento, gets all their motors from them. They told me to go talk to them if I wanted an AWIC as well. Cool to know that you got a good deal from them. Did they charge you the same price as their regular 2.0 longblocks?
Posted: Tue Aug 02, 2005 4:10 pm
by Matt Monson
napphappy,
You're just trying to get me to post my pics of the engine internals, aren't you... ;)
Posted: Tue Aug 02, 2005 4:12 pm
by snowjob
Please please, plese post your pics Matt.
Posted: Wed Aug 03, 2005 2:37 am
by napphappy
snowjob wrote:Please please, plese post your pics Matt.
Yes, I second that
Posted: Wed Aug 03, 2005 10:17 pm
by georryan
Third!
