fuel filter problem???
Posted: Wed Aug 03, 2005 4:44 am
by 90legasyman
After the car sits overnight, before i start the car i need to turn the key on for a couple sec before i can start it, then i turn it on (it takes a couple seconds before it will start). then it runs, put it in drive or reverse, step on the gas then it feels like it will stall after a step or 3, then it runs smoothly after that. so what could be the problem? is it something related to gas? such as the injector or filter or something.
Posted: Thu Aug 04, 2005 3:28 am
How many miles are on it?
Does it do this just when the car sits over night? What about when it sits during the day?
What area of the country do you live in?
It's possible your coolant temp sensor is needing to be replaced.
Posted: Fri Aug 05, 2005 7:48 pm
by 90legasyman
it got 160 k miles on it.
no, not just over night, it also happens during the day when the car sits for more than 2hrs or so. (when the engine is cool)
I live in bend, oregon.
Posted: Fri Aug 05, 2005 8:11 pm
I'd suggest replacing the coolant temp sensor.
It's like 20 bucks from one of the online subaru dealerships.
www.subarugenuineparts.com
Posted: Thu Aug 11, 2005 1:19 am
by 90legasyman
alright thanks, i will try that and see what happens!
Posted: Wed Aug 24, 2005 1:58 am
by 90legasyman
just replaced the coolant temp senser, and wow, it just started right up. how strange one small peice can change a lot for the car! thanks legacy777
Posted: Wed Aug 24, 2005 2:06 pm
welcome
