Page 1 of 2
So, Heres my Girl
Posted: Thu Oct 02, 2003 8:29 pm
by LegacyT
Posted: Thu Oct 02, 2003 8:57 pm
by entirelyturbo
SAWEEEET!!
That is a NICE Legacy! Wow! Definitely worth the work (and I see there was a lot of it
Drooling...
Posted: Thu Oct 02, 2003 9:02 pm
by HomeSlice
YOOOOOOOOO!!!!
that thang is hot!!!!
looks great---i wanna see a pic of the rear end. did you paint the center piece?-i like how you painted your mirrors and your handels---A+ dude
Posted: Thu Oct 02, 2003 9:21 pm
by Brat4by4
Lookin great. Front end looks very clean badgeless and such. Some tint on those windows would complete the package! (If legal of course
Posted: Thu Oct 02, 2003 9:25 pm
by 91White-T
Dayummm those red x's are HOTT!!!
Posted: Thu Oct 02, 2003 10:45 pm
by georryan
So, do you have a different grill in front that doesn't have the subaru badge, or did you just cut it off somehow? I like the mirros painted white, but I probably would have also painted the black triangles they are attached to so that it matches up a little, but it really does look good. I'd like to see your tail section, too. You did some Mondo work to that thing. Awsome job!! Nice rims too
Posted: Thu Oct 02, 2003 11:06 pm
by THAWA
THat really does look hella nice, tint will set it all off, but you cant tempt up like that give us the as...i mean money shot
Posted: Thu Oct 02, 2003 11:08 pm
by LaureltheQueen
That's beautiful. Kudos on the good work and clean car!
Posted: Thu Oct 02, 2003 11:36 pm
by LegacyT
I forced myself to use as little bondo as possible. Instead I used new metal and shaped it as best I could using a bit of bondo to smooth it all out. As for the grille- Its the stocker, I cut out the center section with the badge and painted it all semi-gloss black (not to shiney, but not too dull
) I plan on putting a black painted mesh in there one day. Homeslice- heres the a better pic of the rear, sorry I don't have a direct shot from the rear.
Mark,
Posted: Thu Oct 02, 2003 11:38 pm
by legacy92ej22t
Das ist zer gut....Very nice I like it. Another rearend pick please
(that kinda sounds nasty don't it), I want to see that a little better.
Posted: Fri Oct 03, 2003 12:36 am
by Yukonart
Yeah, that rear end looks really clean!
Love what you've done with the whole car.
Posted: Fri Oct 03, 2003 1:31 am
by mikec
Looks good Mark! Definitely something for me to aim for with mine.
You did all the body work yourself? Did you have some previous experience, or did you learn as you went?
Posted: Fri Oct 03, 2003 1:43 am
by LegacyT
Yup
, well all of it except for the paint. I learned more fixing this car up then any book could teach me for sure. I previously had no experience in body work.
Mark,
Posted: Fri Oct 03, 2003 3:30 am
by Hondaslayer
Any before pics?
i just bought a 91 that was hit in the front and am planning on a very similar scheme.. (arcadia Green,Black roof,black between the tails,Black under spoilers gold WRX wheels)
Ben,
Posted: Fri Oct 03, 2003 3:43 am
by czo79
So you were using metal to fix it, not just bondo? And this is your first job? I take it you knew how to weld previously? I'd really be interested in hearing more about how you did the work.
beautiful!
Micum
Posted: Fri Oct 03, 2003 4:12 am
by Grant
What could I say that hasn't already been said. My first response was, "DAMN, that is a hot legacy." Well worth the sweat you put into it. One of the better looking Legacies I've seen. Definetely makes my top 3. Has everything I like, white car, GT wheels, turbo
Posted: Fri Oct 03, 2003 12:09 pm
by LegacyT
Micum - Yes this car has all new metal in it, no fiberglass anywhere
Actually About a third of the time spent on the car was contemplating how to fix this, or shape that, or attach this thing . Sitting there thinking was a learning experice in its own. Yes I did weld abit and I do suck at it, but I only welded at key points inside the rear quarters since they are stress bearing. Most places I used auto body epoxy and stainless steel body screws. I did have a chance to ask around at first on what way to fix this girl up. I settled on glue and screws since its relatively within the skills of an average handyman I guess and also I heard from many that its better then welding, since your not creating many "hot spots" on the metal which scream I want to rust, in the conditions cars see here. Now maybe if your restoring a 68 shelby then you'd weld up panels nice and seamless, but I'm NOWHERE that good and I'd probobly melt and warp everything and screw the whole car up. Hence I chose glue and screws. In general I'd cut all the rust out, so that its all gone, none outside, none inside the panel. I'd lightly tap the edges of the panel in, to make a lip then cut a peice of new metal out, place glue on the lip, set the peice of metal in and screw it down. Then grind the screw heads down and use filler to fill up any inconsistencies. An don't waste money getting body metal from a store. Just go to an auto body place or dealership that does body work and ask if you can have their collision fenders, they chuck em anyways. These are great, their factory primed on the inside and are already acid dipped to resist corrosion. All you have to do is flatten them out and grind the external paint off since it'll crack and break off when you bend the metal to shape, leave the factory primed side though.
Mark,
Posted: Fri Oct 03, 2003 2:14 pm
by NuwanD
that's one sweet "junker" ... very very nice, i like the blackout grill on white as well
i've always wanted to save every legacy turbo that i saw in a wreckers but i have no place to put them
Posted: Fri Oct 03, 2003 4:17 pm
by LegacyT
You've actually seen one in a yard? Oooo where in Ontario
Mark,
Posted: Mon Oct 06, 2003 1:25 am
by imprezausa
Posted: Tue Oct 07, 2003 4:38 am
by carguy327
Nice work!!
I start work on mine in the spring.
Like you, it'll all be metal
Gerald
Posted: Sun Oct 12, 2003 7:08 am
by turbonator
Nice car I am in ottawa also
Posted: Wed Oct 15, 2003 6:55 pm
by LegacyT
Where abouts? What kind of car do you drive? I'm in Kanata
Mark,
Posted: Wed Oct 15, 2003 7:51 pm
by turbonator
I just bought a 91 turbo and my buddy who got me interrested in these car has a 92 turbo.
I am in QC just across the bridge and my buddy lives near bronson We go crusing almost every night so let me know if you would like to go cruising?
Posted: Wed Oct 15, 2003 7:57 pm
by LegacyT
Cool will do, just need to finish up work on the power steering.
Mark,
