93-94 SS: Anyone running this swaybar...
Posted: Thu Aug 04, 2005 1:14 am
by rightandtight
Is anyone running the Whiteline 22mm front bar BSF19X on their 93-94 SS?
In Whiteline's catalog it says the above bar will fit 92-97 BD,BG excluding Turbo. I found this bar for $120 new, and I think it might fit, but looking for some conformation.
The 22mm front bar for 93-94 SS in their catalog is BSF18X. I can't find this bar anywhere and the wait is 6-8 weeks from Aus.
Thanks,
Willie
Posted: Thu Aug 04, 2005 8:40 am
by LaureltheQueen
it's more than 6-8 weeks if you got those numbers from pdm-racing
I believe it has to do with the turbo piping clearance.
Posted: Thu Aug 04, 2005 2:45 pm
by rightandtight
Yeah, that's what I was thinking last night about the extra room for turbo related stuff being the difference.
I saw a few posts dicussing the possibility of a WRX wagon front bar fitting, as the wagon might have a shorter track than the sedan.
Posted: Tue Aug 23, 2005 5:32 am
by Subtle
Last December I took my turbo wagon out to PDM-- they had an
adjustable(20-22-24) rear bar and it was installed in half an hour.
However, on the wet and sometimes snowy roads the slight oversteer
was uncomfortable. The 20 front bar was ordered in January and it
was installed in Feb. Handling with 20 front and 20 rear is moderate
understeer and when the car is ready for some track time I can "dial"
out the understeer.
In the meantime, the improvement in handling is well worthwhile,
particularly with a load of camping gear and a couple of WW canoes
on the roof rack.
The guys a PDM dont get many calls for a front bar for the Impressa,
and next to none for a Legacy.
Posted: Tue Aug 23, 2005 2:04 pm
by professor
where did you find that bar ? I wouldn't mind having one of those, I personally feel with the 18mm rear bar in a wagon, that the front stock bar is too small, and the one you call out would be perfect
Posted: Tue Aug 23, 2005 5:40 pm
by JasonGrahn
they had an adjustable(20-22-24) rear bar and it was installed in half an hour.
Such a pet peeve of mine.
Can someone explain to me how one can adjust the actual thickness of the sway bar?
Posted: Tue Aug 23, 2005 5:43 pm
by scottzg
on a lathe ;)
Posted: Tue Aug 23, 2005 5:57 pm
by BAC5.2
Don't they usually have a diameter of 22mm, and 3 mounting locations. The middle would be stock length, the front hole would be longer than stock (allowing lesser spring rate, more leverage on the bar), and the rear hole would be shorter than stock (allowing more spring rate, less leverage on the bar).
It's more of an "acts like a 20 or 24 bar" than an acutal adjustable bar.
At least that's my view.
Posted: Fri Aug 26, 2005 5:54 am
by Subtle
Professor---Sorry I overlooked stating that it was Whiteline
bars, links and bushings, and that they make the stuff
to fit older Legacys.
BAC5.2-- That's how they adjust.
Very pleased with the results
