best way to drain old gas?
Posted: Sat Aug 06, 2005 7:45 am
by 206er
Im just about ready to fire my new motor(22E heads on 2.5 block) and I need to do it with good gas, not the 2 month old 87 octane thats in there now.
are those 2 bolts on the bottom of the gas tank that look like drain plugs actually drain plugs? if they are that will be the best way to do it, but dealing with so many broken bolts has made me cautious to try and loosen stuff I dont have to.
I have heard you can clear the tank out with the fuel pump, but am not sure how to do this. would I disconnect the coil pack, route the fuel line into a can and turn the ignition on to start the fuel pump? this sounds nice and easy but maybe it wont get all the gas out. opinions please.
Posted: Sat Aug 06, 2005 3:20 pm
I think you could do it with the pump, yeah. You could disconnect the feed line from the fuel filter and use a 5/16" hose joiner and some 5/16" fuel hose (it doesn't have to be EFI hose for this purpose) to redirect it into a fuel container.
Then you'd put the ECU into test mode (connect the green connectors) and leave the ignition in the ON position. The ECU would pulse the pump on and off repeatedly, eventually emptying the tank.
Posted: Sat Aug 06, 2005 3:34 pm
by Manarius
You could just siphon it out. It would be a lot easier then trying to rig up the pump.
Posted: Sat Aug 06, 2005 5:03 pm
There are drain plugs in the gas tank on the bottom in which you can drain the gas out.
Posted: Sat Aug 06, 2005 6:28 pm
by professor
gas going "bad" is largely a myth
Posted: Sat Aug 06, 2005 6:41 pm
by Manarius
professor wrote:gas going "bad" is largely a myth
I don't think it's the old thing he's worried about. I think it's the "87 octane" part.
Posted: Sat Aug 06, 2005 7:21 pm
by 206er
word.
so the bolts on the bottom of the tank are indeed drain plugs?
Posted: Sat Aug 06, 2005 8:07 pm
by Penguin
90-91 have drain plugs 92-94 don't
Posted: Sat Aug 06, 2005 9:08 pm
by 206er
great, mines a 91. thanks for the replies everyone.
damn things going to run today, come hell or high water.
Posted: Sat Aug 06, 2005 11:41 pm
How do the drain plugs seal?
Posted: Sun Aug 07, 2005 3:14 am
by 206er
well, theres no seal. its just a bolt. :? not even a crush washer.
Posted: Mon Aug 08, 2005 6:07 pm
by Penguin
yep just a bolt(s) no washer from the factory. and now my 93(had a wierd hole) has a 91 tank, i just swapeded them this weekend... drain plugs are nice.
(i pooked 2 holes in mine old to get the gas out)
Posted: Tue Aug 09, 2005 4:48 am
Bolts don't usually seal on their own... I'd stick a crush washer on there to seal it when reinstalling it.
