Stupid Question
Posted: Wed Aug 10, 2005 5:30 pm
Before I psted this question, I searched to see what the answer was. My situation is a little more unique then what the answers applied to.
Now, I wanted to see what kind of differential my car had. I searched and the method to test is jack up the rear and spin one of the tires. If the other moves in the same direction, you have an LSD. If the other moves in the opposite direction, you have an open (effectively a 2WD car). Well, I did that just now and I spun one of the tires and the other one didn't move at all
. Do I have a broken differential or what? Note though that when I turned the back wheels, it turned the driveshaft. Do I need to be worried?
