getting CEL for 3 solenoids. help
Posted: Thu Aug 11, 2005 2:21 am
Sometimes, I get these codes:
24, 35, 44 (Idle air control solenoid valve, canister purge solenoid valve, wastegate solenoid valve)
But here's the weird thing:
75% of the time, I get no codes and the car runs great (idles and boosts fine, suggesting those solenoids are ok).
But when I do get the codes (25% of the time), I get all three of those codes together. I NEVER get just one or two of the codes - it's all or nothing. All that suggests that the solenoids are fine and instead we are dealing with something systematic.
I replaced the ECU, and all the same codes come up. That suggests that the ECU is not the problem.
Resistance measured AT the solenoid:
Wastegate solenoid: 20.7 Ohms
Resistance measured inside the passenger compartment on the harness connector that normally connects to the ECU
Wastegate solenoid: 21.4 Ohms
IAC valve (close end): 10.2 Ohms
IAC valve (open end): 10.2 Ohms
Canister purge control: 43.3 Ohms
(to measure the resistance of each of those, I put one probe on each of those pins and the reference probe on pin 5 of the Select Monitor connector becuase that was the closest place I could find where the "common" was broken out)
Any ideas what could be wrong? It seems like the solenoids check out, the harness checks out, and the ECU was eliminated because I swapped and still had the same problem. I'm pretty desperate to get rid of this!!!!
