S-AFC Wiring
Posted: Sat Oct 04, 2003 4:17 pm
by 91White-T
I was lookin at gettin an Apex-i S-AFC, but the wiring manual doesn't list a diagram for a 89-93 BC EJ22T, only for the EJ20G ... Does anyone know if the ECU harnesses are the same for the EJ20 and 22?
Posted: Sat Oct 04, 2003 5:32 pm
All BC/BF ECU harnesses are almost the same. Small differences exist when they have to (like to accomodate 4-channel vs. 2-channel ignitions, or for the air/water intercooler, or for boost control), and the cam and crank sensors are switched for turbo and non-turbo models, but I don't think any of that matters for the S-AFC.
You could compare the wiring guide's suggestions for the EJ20G with the EJ22T pinouts:
http://www.graphics.cornell.edu/~v/ecupins/
And see if they make sense.
Posted: Sat Oct 04, 2003 6:52 pm
by 91White-T
Hmmm... It looks like all the stuff the AFC uses is the same. Now to find a good deal on one...
