Allen key in armrest???
Posted: Fri Aug 19, 2005 5:20 am
by Soobster
What is the allen key lodged into the under side of my center armrest lid suposed to be for?
Really really puzzled about this one.
Posted: Fri Aug 19, 2005 5:26 am
by THAWA
sunroof. Manually wind it when it's stuck.
Posted: Fri Aug 19, 2005 5:44 am
by IronMonkeyL255
Also for the automatic seatbelts. If they get stuck, you can just crank them back.
Posted: Fri Aug 19, 2005 8:40 pm
by tris91ricer
Correctamundo for the most of us --it's for the seatbelts. That sunroof isn't endangering you when something happens. The seatbelts are.
Posted: Fri Aug 19, 2005 9:53 pm
by LaureltheQueen
if the sunroof gets stuck open though, it could potentially damage not only cargo, but the vehicle's interior
Posted: Fri Aug 19, 2005 9:58 pm
by IronMonkeyL255
and if the seatbelt gets stuck forward, you could be damaged yourself.
The point is, it is for both of them. There is a little cap in the middle of the headliner in the back that conceals the sunroof crank, and there is a similar plastic cap on the b-pillar trim towards the bottom that conceals the seatbelt crank spot.
I should know. I've had to use them both.
For some reason, my old passenger side seatbelt hated my brother. It would only screw up when he was in the seat.........
Posted: Sat Aug 20, 2005 12:33 am
by LaureltheQueen
perhaps i should get something to replace that allen key.
Posted: Sat Aug 20, 2005 1:31 am
I keep a 5mm allen "socket" and a ratchet in the multibox.
I think it's 5mm, anyway.
Posted: Sun Aug 21, 2005 8:52 am
by AWD_addict
multibox ownz allen key
