Page 1 of 2
its time for a better turbo
Posted: Sun Aug 21, 2005 10:36 am
by NICO
right now i got the factory turbo with t-bird set up, what should i get
Posted: Sun Aug 21, 2005 4:01 pm
by -K-
Holset HY30 or HX35. They use the Garrett flange so you would need to do some exhaust work.
Best bang for the buck turbo out there right now but the word is getting around and the price is going up some.
Posted: Sun Aug 21, 2005 7:20 pm
by gt350
no I'm still a little new here but are there management options and injectors out there to support a turbo that large? a hx35w is a large turbo wich flows 55lb/min. the hy30w flows in the neighborhood of 35-40lb min. don't have that one memorized. also the hx35w has a 12cm housing which would be no fun to spool on a subaru. the HY35w has a 9cm housing and isn't a divided housing like the hx. it still flows 55lb/min. but I think the holsets are a little large unless he want's to make 350+hp. a 16g or t3 60 trim would be more ideal. they both flow about 34lb/min and the 16g as we know is a direct bolt on. I plan on making a up pipe and attempting to install a garrett t3 60trim more or less to see if I can do it. for me it would be a very cost effective solution seeing as how I have a few of them. and if it works I would open options for any turbo I would desire. well almost.
Posted: Mon Aug 22, 2005 12:12 am
by -K-
He wants stupid power I bet and I think he is getting a Greddy Emanage and STi injectors.
I have driven a 2.3 Ford with a HX35 and it was OK. I wouldn't run it at less than 20psi. It's a twin scroll so if you made a Header with a twin scroll up pipe it would spool up better.
The HY30 would make a better street turbo and would be my first choice for a BIG turbo.
The Holset quality and design are far better than Garrett T series.
I don't think many people would need more than a 16g and it bolts to the up/down pipes so it's a good choice if you don't need stupid power.
Posted: Mon Aug 22, 2005 1:53 am
by gt350
ok I see. didn't know his goals. so you drove a 2.3t with a holset. was that reeve's capri? I actually have his milled housing for my hx35w. I'm also a turboford nut. thats my real pride and joy. the leggy is just for fun. I agree with you on the quality of the holsets there a very nice turbo.
Posted: Mon Aug 22, 2005 4:24 am
by azn2nr
hx35y with a bullseye exhaust housing for the 2.2 would be the best bet. its a little smaller so it spools better. the standard housing on a 2.4 axis motor with an auto at 5k stall rpm's is breathtaking. external wastegate probaly best. tial 48mm or larger unless you want to bring the noise
Posted: Mon Aug 22, 2005 5:08 am
by georryan
-K- wrote:He wants stupid power I bet and I think he is getting a Greddy Emanage and STi injectors.
LOL, we know Nico all to well.
Posted: Mon Aug 22, 2005 5:09 am
by georryan
LOL, we know Nico all to well. Good luck Nico.
Posted: Mon Aug 22, 2005 8:14 am
by azn2nr
btw. nico already has the emanage and injectors.
Posted: Tue Aug 23, 2005 4:38 am
by THAWA
What happened to your 350 whp turbo?
Posted: Tue Aug 23, 2005 7:09 pm
by NICO
ya i got the e-manage an sti injectors all working in good order, thats the problem i need more boost power the turbo cant push no more.
here is what i got a tdo4l from a wrk and a vf30 from a sti, also i have some garret turbos that i think came off a GN turbo 60 a/f they say. i have 600 canadian to work with
thawa 350 sounds just about right, i do have my turbo legacy set in a 95 subaru impreza L sedan, with no power nothing its about 600 700 lbs less then my turbo legacy ways. i raced a 11 sec neon on the streets a month ago and did he ever see STARS ding ding
Posted: Wed Aug 24, 2005 1:39 am
by THAWA
So your VF11 hybrid is making 350 WHP?
Posted: Wed Aug 24, 2005 2:58 am
by J-MoNeY
I'm making 568WHP on my stock VF-11. It's only feesible that he's making that low of a HP number.
Posted: Wed Aug 24, 2005 6:28 am
by -K-
I'd use the VF30 and see if it has enough for you. You won't have to mess with the exhaust so big plus there and it should be a good bit better than the VF11.
gt350, yup Reeve's Capri. That thing is a monster when the boost comes on. I should have guessed you were a 2.3 guy, nobody else seems to know about them Holsets.
azn2nr, good point about the external gate, forgot that part. I don't think anyone is set up to run stock wastgate boost on a Holset here.
Posted: Wed Aug 24, 2005 4:54 pm
by azn2nr
yeah, trying to tune a holset at wastegate boost (20psi) right off the bat would be a bit risky.
Posted: Wed Aug 24, 2005 6:40 pm
by NICO
k you think it would be a little better then my stock one, my stock one is good but it needs a little more. maybe the vf 30 would be good.
hahahahah j-money that was killer its only feesible.
Posted: Wed Aug 24, 2005 7:01 pm
Well, it's not even clear that the Holset's internal wastegate would be up to the task of regulating boost on a spark-ignition engine...
Posted: Wed Aug 24, 2005 8:35 pm
by NICO
vrg3 what turbo do you think i should put on my car, i do but dont want to custom the hole thing but if there is nothing i can do then i geuss i have to. but the car needs more turbo power.
Posted: Wed Aug 24, 2005 8:38 pm
by legacy92ej22t
18G or Super 16G
Posted: Wed Aug 24, 2005 9:00 pm
by NICO
i tried looking for this tdo5-16g and i am having no luck, there is no one in canada that has this turbo.
Posted: Wed Aug 24, 2005 9:09 pm
You might consider buying one from Deadbolt:
http://www.deadboltspeed.com/
If you ask nicely you could probably get them to weld an inlet elbow on, and maybe reclock it too, to make it close to a drop-in replacement.
Posted: Wed Aug 24, 2005 9:31 pm
by NICO
ya vrg3 that would be perfect i would need to clock it becuse the way i have the front mount set up, and then you need that dame 90 on there.
WHY SUBARU have you made it so hard to upgrade my turbo for a motor that does not want to BLOW APART.
Posted: Wed Aug 24, 2005 10:05 pm
by georryan
Deadbolt makes 16Gs with it clocked like the vf11.
Posted: Thu Aug 25, 2005 1:29 am
by dzx
I like the t3/t4 and enjoy the stupid power....unfortunately its been bucking at more than 5lbs of boost lately. Seems like misfires or something.
Posted: Thu Aug 25, 2005 2:19 am
by THAWA
Why are you downgrading to a 16g? If your turbo is making 350whp this would be worse.
