strange sound
Posted: Tue Aug 30, 2005 6:37 pm
by Kcwiro
Hey I have a 2.2 99 legacy sedan that is making a kind if sqweeking noise when it is at idle...I know the engine chriping is normal but I don't think this is that...
Anyway when the car is idling the noise is there but if I press on the clutch pedel just a hair the sound goes away comes back when I release i take my foot off... not sure what to lube / check / whatever give me a hand boys and girls.
Posted: Tue Aug 30, 2005 10:21 pm
by Gotta Jibboo
Throwout bearing?
I think that's what it's called, I don't know much about 5MTs
Posted: Wed Aug 31, 2005 2:36 pm
by professor
the throwout bearing is not loaded at idle and would act opposite what you have if bad. so it could be an input shaft bearing on your tranny
you may have to learn to live with this one
Posted: Thu Sep 01, 2005 4:29 am
by THAWA
Wait, isn't that how a bad throw-out bearing acts?
Posted: Thu Sep 01, 2005 6:15 am
by douglas vincent
I suspect throw out bearing.
Get a 2-3' section of garden hose and put it up against the tranny. You WILL hear something. Then have a buddy press in the clutch.
Now do this over and over on different areas and you should pinpoint the area of the squeak.
Dollar to a donut its the throwout bearing. But also check your tranny fluid.
Posted: Thu Sep 01, 2005 2:51 pm
by professor
yes it is possible for the throwout bearing to make noise in neutral with the clutch not depressed. But it usually won't shut up when the clitch is pressed. That's when the throwout bearing is doing its job and is most likely to make noise
noise that shuts up completely the instant the clutch is pressed is more likely to be a pilot bearing or the input shaft bearings in the tranny. Under no load those bearings are spinning freely and are thus free to whine and rattle if worn
