Diagrams and questions
Posted: Thu Sep 01, 2005 4:42 pm
1. does anybody have a diagram showing where the hoses for the wastegate solenoid attach to?
2. also, on the turbo block, there is one hose to the outside of the enging behind each spark plug, is that part of the EGR or PCV or whatever the hell it's called? Basically what i'm asking is, do i have to try and plug those in or can i leave them disconnected?
3. Anyone have a diagram or know which wires you have to add/switch on the ECU in a ej22t swap?
4. is there any good way of removing the tranny cooling lines from the transmission w/o removing the trans?
oh yea, this is all on a 91 L, swapping to ej22T.
ps, anyone that could help out would be greatly appreciated. the engine is in and it's down to tubes and wires
