Does anyone know...?
Posted: Wed Oct 08, 2003 6:30 pm
by Dr.Outback
Does anyone know of any company that specifically makes an intercooler for a '93 Sport Sedan, or do you have to modify an intercooler from another car? Thanks
Posted: Wed Oct 08, 2003 7:49 pm
by LegacyT
the only company that specifically made an intercooler for the 1st gen turbo's was subaru itself. oversea's spec turbo's had an air/water intercooler stock. We in North America didn't get it, so the only option is to modify one to get it to fit. The air/water intercooler from subaru is a pain to setup since these cars didn't come with the nessesary support systems to implement one. You'd be better off putting in a wrx, saab 900, or 93-96 slant WRX intercoolers.
Mark,
Posted: Wed Oct 08, 2003 8:07 pm
by Brat4by4
Hmm... personal opinion seeped in there somewhere. Any intercooler is going to need a custom made pipe from the turbo to the intercooler inlet. Which is also where the stock recirculation valve resides.
But, to sum up. There is no intercooler on earth (that we know of) that you can just buy and plug straight into a USDM Legacy turbo. All will need custom work. Saab 900, 93-96 WRX top mount, and oversea's spec Air-water are the most popular put in these cars and will have some research into what works and what doesn't.
Posted: Thu Oct 09, 2003 12:36 am
by LegacyPunk
Your best bet would be a SAAB 900 IC or a air/air USDM WRX IC. Or if you have the money, get a custom front mount or top mount from spearco or someplace.
Posted: Thu Oct 09, 2003 2:55 am
by Dr.Outback
Well, so what you are saying is that it will take hours of work and head banging to install one. Maybe I will just be happy with it stock for now. It's such a big upgrade from my '84 GL wagon.
Posted: Thu Oct 09, 2003 8:27 am
by georryan
Hours of work and headbanging? That may not be the case, but it will take a little work. The air/water intercooler will give you the best results from what I understand with everything else stock. The air/air top mounts won't get sufficient air from the little scoop on our hoods, but unless you want big power, they should work fine. The down side to the air/water is that you need to find a water pump, and a radiator like thing to stick on the front of the ac condenser. The water also will add weight to the front end of your car. So all things considered, there is posative and negatives to all of them. The easiest to put in will probably be the saab or the slant wrx intercooler (ver 2 I think). All that I've learned from just reading posts, not necissarily from personal experience.
Posted: Thu Oct 09, 2003 2:23 pm
by Dr.Outback
I'll have to keep my eyes open for any good used intercoolers.
Posted: Thu Oct 09, 2003 6:20 pm
by pjgaerlan
Check Ebay for WRX ICs.. I just saw two yesterday on there. I fit my Saab one but I'm gonna try and fit my WRX IC for the Rallycross this weekend. Good luck
PJ
Posted: Thu Oct 09, 2003 11:44 pm
by czo79
hmmm....
I wonder if I have a lot more room for a topmount IC since I have the Ej20G and its throttle body sits farther forward...what I'm getting at is, maybe I could run a better, larger IC, maybe a spearco or something aftermarket from a latter wrx or somethings, and then sell my early wrx slant for a pretty penny...
hmmm
Micum
Posted: Fri Oct 10, 2003 4:49 am
by Brat4by4
or give someone on the board a decent deal
and i don't mean me, i already have one far superior to yours
Posted: Sat Oct 11, 2003 4:27 am
by Hondaslayer
Got curious and pulled the Rallispec I/C off my RS-t and put it on the legacy today,and it fits rather well,downside they are very pricey ($750)
