Cable clutch to hydraulic or not?
Posted: Sat Sep 17, 2005 9:55 pm
Hi again-
I've got an EJ22T engine from my old SS (where it had a 4EAT) and a low low mileage 5MT from an SS. Great so far, right? Well I want to put them in my 1990 NA 5MT shell. Cable clutch.
So my questions are:
1. Can the cable clutch be made to work on the 5MT SS gearbox? I happen to have a very new clutch in the NA already. I'd prefer just to use it.
2. If not (or even if so), what pedal boxes will work? I have no slave on the 5MT SS box so whatever rig I get I will need the whole hydraulic system from pedal to clutch fork. What will fit? Up to and including WRX?
A.
PS I've got the low, low mileage SS rear diff already so no worries about the ratios. And yes I thought of using the 4.11 gears from the NA diff in the SS diff and just keeping the NA gearbox, mating it to the EJ22T. But the NA gearbox is veddy veddy noisy. Worrisome noisy. Also I cruise at about 80mph and by my calcs in fifth that's just where torque peaks with the 3.9. You drag racers can run 4.44s. My rally car tops out at 120mph at 7000 in fifth. Great for rally. Sucky for the road. Want longer legs. 3.9 fine.
A
A.
A
