tick tick tick tick.............?
Posted: Tue Sep 20, 2005 12:21 am
by nsantos23
hi all
i now its not a stone stuck on the tires threat, i know its not my valves that are ticking, the noise comes from under the vehicle and not the engine, what may it be? it only makes the ticking noise when i accelerate and can only be hear if i drive by the median.
thanks in advance
Neo
Posted: Tue Sep 20, 2005 12:42 am
by Manarius
Could be CV joint. Check to see if any of your boots are broke.
Posted: Tue Sep 20, 2005 12:51 am
by jd_1185
mabe an exhaust leak
Posted: Tue Sep 20, 2005 1:14 am
by nsantos23
one of my boots is ripped, that can make a ticking noise?
Posted: Tue Sep 20, 2005 1:18 am
by jd_1185
it can if there is no more grease in the boot
dose it get louder when you go around a corner?
Posted: Tue Sep 20, 2005 1:19 am
by Manarius
nsantos23 wrote:one of my boots is ripped, that can make a ticking noise?
It could. And besides, it's time to replace that half-shaft. Not a good idea to be driving around with broken boots.
Posted: Tue Sep 20, 2005 2:33 am
by nsantos23
nahh is not making noise when i turn, but the ticking is there under acceleration, i thought it was my tranny, but now it all makes sense
Posted: Tue Sep 20, 2005 3:41 am
by greg donovan
it sounds like an inner joint is bad.
what boot is torn?
Posted: Tue Sep 20, 2005 4:00 am
by skid542
Sounds exactly what I have and it's my driver's side outer CV joint. The boot was ripped when I replaced the engine and it had been making that noise for a while. If you go up under, look at the boot and then yank and pull on the axle. Then go to the other side and do the same. Any difference?
