Swapping a 2.2 91 engine to 2.0 92/93 turbo
Posted: Fri Sep 23, 2005 1:38 pm
by lordis
How much work is this? Do I need to swap the transmission too?
btw, great subaru forum
Posted: Fri Sep 23, 2005 4:47 pm
by Matt Monson
Your title is confusing as hell. Can you clarify what you are looking to do so i don't type a long reply guessing what you are doing?
Posted: Fri Sep 23, 2005 5:27 pm
by scuzzy
Swapping a 2.2 91’ engine to 2.0 92/93’
Posted: Fri Sep 23, 2005 6:42 pm
by tris91ricer
Let's just answer his question in general terms. It looks like he's going to replace an EJ22 with an EJ20.
Knowing what we do about Subarus, let's let him in on the legos secret.
Any Subaru EJ engine will bolt up correctly to any tranny that would normally accompany an EJ engine, no matter the model.
Your only worry should be OBDI and OBDII.
Does that help?
Posted: Fri Sep 23, 2005 7:02 pm
by Busdriver
I thought there was a difference between Turbo and N/A trannies ??
As in the Turbo being the strongest made...
same shaft?
Posted: Fri Sep 23, 2005 7:04 pm
by tris91ricer
Busdriver wrote:I thought there was a difference between Turbo and N/A trannies ??
same shaft?
For ATs and MTs, shafts are the same, being that in AT, the driveshafts are shorter, due to the entended length of the AT tailhousing. He's talking about motor swaps, I don't want to feed him too much at once, and tranny info, in particular, unless he needs it, in which case, I hope he starts the appropriate thread.
Posted: Sun Sep 25, 2005 12:17 pm
by lordis
Sorry for the bad subject in my first post. What I meant to say was how much work it is to swap a 2.2 to a 2.0 turbo. Need to know what other parts except the engine that needs to be changed..
