trans pan gasket
Posted: Tue Oct 04, 2005 2:16 am
by subaru girl
just got the pan gasket on for the 2nd time and it leaks in the right front corner of the pan same as before. all the old gasket is off and it still leaks in the exact same place. any ideas
Posted: Tue Oct 04, 2005 2:21 am
I don't know autos, but is it possible the pan or even the transmission body is bent or dented or something?
Posted: Tue Oct 04, 2005 2:31 am
by THAWA
There's a gasket? I thought you had to use threebond? Anyway, I'd agree with Vikash that there may be something deformed.
Posted: Tue Oct 04, 2005 9:46 pm
There's a gasket for the AT pan.
Make sure that both the transmission and pan are clean of all the old gasket material.
Also, the bolt holes on the pan can get bowed. Take a hammer and lightly tap them so the mating surface is flat.
Posted: Sat Nov 05, 2005 2:57 am
by TurboSubie
had this same problem on my old N/A...spray form a gasket on the gasket...works like a champ:)
