CEL on when warmed up or at low idle
Posted: Mon Oct 17, 2005 11:24 pm
Hey all, what could be the cause for the CEL to be off when just starting out, but turns on after about 3-5 minutes, or when the idle falls below 1k. Tired to retrieve the code, but nothing shows up. Also when I connected the green ECU plug, and turned to ON, the radiator fan cycled on and off, and it sounded like some relay about the fuse box was clicking on and off with the fan
