Turn signals not working
legacy3kgt
Post by legacy3kgt »
I have a 91 legacy and my turn signals won't work, however the hazard lights do work. any ideas?
(indicator lights don't turn on or anything)
-->Andrew
SuperDoo Ownz Joo
HomeSlice
Post by HomeSlice »
id check fuses first. but it might me the steering combo switch.
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
I think I'd suspect the hazard light switch first. I believe the hazard light switch is required to complete the turn signal circuit when the hazards aren't on themselves.
mikec
Post by mikec »
vrg3, you're right. I let my hazard light switch unplugged one day while messing around behind the dash, and didn't have any turn signals.
But if the hazard lights are working, then it sounds like the switch is plugged in. Hmm...
HomeSlice
Re: Turn signals not working
Post by HomeSlice »
legacy3kgt wrote: however the hazard lights do work. any ideas?
:D --also check the relays
Okay, I've got my wiring manual now. There aren't any relays.
First thing to check -- is fuse 1 in the passenger compartment fuse box okay? It supplies power for the reverse lights and turn signals. Hazards go through fuse 22 in the underhood fuse box.
And you are testing the turn signals with the ignition on, right?
Failing those two things, you'll have to test the hazard switch and the turn signal switch separately off the car to find out which one is faulty.
Post by entirelyturbo »
To bump an old-ass thread, I have a question for my friend renmaxi.
His 91 turbo will blow a fuse when he tries to use his turn signals. Sometimes it happens immediately, sometimes it takes a while. We're both electrical idiots, so are there any suggestions as to where to look for a problem? Reading this thread, I might ask him about his hazards...
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
subawhatsubawho
Post by subawhatsubawho »
I had something like this in my BC. Whenever I Would turn the lights on the interior lights (guages, HVAC, radio) would crap out.
Turned out the illumination wire that goes to the radio had been cut once and the idiot just taped it back togheter. Tape came off and would short out and blow the fuse. But it didn't happen all the time so it was driving me nuts.
1991 Legacy BJ L 5MT AWD 189K Paid $100 STOLEN 2/13/06
