headlights....
Posted: Fri Oct 17, 2003 6:16 am
I got to pull out my xtra set of headlights...but looking at that picture in the motorsports forum of the yellow legacy w/ reverse cold air scoop and weird headlight setup...
Well, I've though a lot about how our headlights could be replaced. I found these lights that look pretty good:
http://www.susquehanna.com/susq/hella/90mm.htm
They are 90mm round...small like projectors, but I think maybe they are reflector lamps. Anyways, I was thinking maybe these are compact enough that there is enough room with them for us to have a quad lamp setup. I just can't decide what the best way to do it would be. I was thinking about the possibility of making something out of fiberglass, or sheetmetal, or something...that basically fills the hole left by removing the stock lamps, and has approx the shape of the stock lights. It would have two holes for the hella lamps, but maybe with a tapered lip going into the holes towards the lamp. The assembly could be painted body color...or black or something. The other thing I was thinking, and I have to take a look at the stock lamp design, is maybe one could gut the stock lamp assembly and somehow mount the hellas behind the plastic lens of the original stock headlights.
Maybe I will see if I could photoshop something up...
What does everyone think?
Micum
Micum
