What kind of oil for LSD?
Posted: Fri Oct 17, 2003 9:47 pm
by ej22t
Hi guys, just done the LSD diff. swap and now I have to go to change the fluid. Since the open diff that I used has I was using the Redline 75W90NS. Now I have the LSD on it, so what kind of fluid should I use?
Please help and thanks!
Ben
Posted: Fri Oct 17, 2003 10:53 pm
I'm pretty sure Redline 75W90NS is the recommended Redline oil for the LSD too. The limited-slip part is sealed so it's treated the same as an open diff.
Posted: Fri Oct 17, 2003 11:18 pm
by ej22t
Thanks for your info Vrg3
How about Motul?
Which one should I use to change the LSD fluid?
Ben
Posted: Fri Oct 17, 2003 11:33 pm
by kelley
I like neo. I use it in my engine, tranny, and diff.
Posted: Sat Oct 18, 2003 3:28 am
by JasonGrahn
ditto on neo. i get it from hairpin racing in oregon.
Posted: Wed Nov 19, 2003 8:14 am
by ciper
Just to repeat what was already said, any type of fluid intended for a standard differential. When you ask which to use make NO MENTION of it being an LSD or you might get the wrong stuff (with friction modifiers).
