boost at lower temps
Posted: Sat Nov 19, 2005 8:37 am
The high setting on the Profec B has been at 12 #. No change since.
With the cooler weather( 40 F ) and WOT its been registering 14 #.
Seems OK-- the wideband (with no change in the ecu) is still showing rich at 11.75.
The acceleration has noticeably improved.
However, given the half-life of performance increases, within a month or
so more is needed
so more is needed
