Strut bearing issues
Posted: Sun Nov 20, 2005 3:29 am
Hey Guys, Maybe someone can help.
I bought new struts at Autozone for my 92 legacy wagon 4wd. I need to know if anyone else had experience with Gabriel struts because now I have popping from my struts coming from the strut bearings on both sides when i turn the steering wheel. This popping was not present with the stock struts even though I have removed them before.
I know that I installed the struts correctly because I have done this before on this car, but never had this happen.
1. Do Gabriel struts require Gabriel strut bearings or
2. The washers underneath the top hat are excessively worn?
I also checked for proper spring installation and they end is in the recessed spot just like my 00 forester.
Any thoughts would be great before I put the old struts back on so at least I can drive the car.
thanks,
Be McMillon
thanks,
Be McMillon
