VF 34 turbo
Posted: Sun Nov 20, 2005 6:18 pm
by Subtle
Does the 34 come clocked to fit the ej22t :?
Posted: Mon Nov 21, 2005 7:52 pm
by georryan
The only turbos that come clocked to fit a stock ej22t that I know of are the vf11's and the modified tdo5 from deadbolt.
If you have an intercooler fitted behind the throttle body (AWIC, or some WRX intercooler, etc.) you can still get some bolt up turbos.
These turbos have the same 90 degree elbow in the intake side of things but the part going to the intercooler is straight rather than clocked upwards. These turbos would be the vf10, vf8, vf12, tdo5-16G.
The last turbos would need some fabrication to fit when it comes to the coolant tank up near the intake manifold and the breather lines behind the throttle body.
All the other turbos you'll find (vf34, vf22, vf23, tdo4, etc.) have a front entry that doesn't make a 90 degree bend and would require modification to hook up to your MAF and intake piping.
It has been done though. It isn't too hard to have a place make you an adapter that can act as that 90 degree bend.
Posted: Mon Nov 21, 2005 9:12 pm
by Subtle
Have a custom fmic fitted to the original vf11, so the question becomes
what is the angle of the outlet on the turbos that fit the WRX :?
Posted: Mon Nov 21, 2005 10:51 pm
by georryan
All the turbos other than the vf11 and modified tdo5 from deadbolt are the same. They all come out straight to plug into a pipe that would go to an upper fitted intercooler.
Hope that helps :)
