Page 1 of 2
BAD Mood....
Posted: Tue Nov 29, 2005 5:31 am
I'm sure everyone has had one of those days...or possibly one of those evenings where nothing goes right, and it just sets off a bunch of shit, and you just want to beat the crap out of something!!! Well I'm having one of those evenings. Everything was fine when I came home....go to the gym.....come back.....and that's when it started.....it may be little, but it's the little things that just continue to work at ya.
My weather station thingy-ma-bobber's (technical term) outside sensor just stopped working for some reason. I cleaned it, since it had been outside for a while. I then replaced the batteries....which were fine. But then the damn sensor doesn't show up. Well there's a certain order you have to install the batteries and shit to get it to work. I can't get the damn sensors to work right together, and I've been f'n with it all night. So that's been working at me.
Next is the fucking cable modem. It just cuts out for a few minutes.....works.....and then cuts out. I was on the mother fucking phone with time warner on sunday for 45 minutes....routed to someone in toronto....and then somewhere else in the US....then to Houston......all to have them say....well we really can't do anything if it's intermittant....call us back when you're having the problem. So basically they can't do shit!!!! FUCKERS!
Now on to the car.....A buddy called, and I was talking about the car, and some of the issues I've had.....well that got me worked up about all the damn money I've spent on the POS, and all the problems that continue and continue and continue. The biggest one right now is that overpriced piece of shit driveline scraper......why....because as of now, there doesn't appear to be an easy solution.....and second, I'm getting about as much support from CES as I am from Time Warner....maybe a little worse.....at least someone from Time Warner will tell me they can't do shit for me.
So that is my wonderful evening.......oh....and I have to travel tomorrow morning for work.....yay.....
I like venting....you couldn't tell could you....too bad it doesn't fix anything......hopefully your evening has taken a better turn then mine.
Nighty.....night
Posted: Tue Nov 29, 2005 6:11 am
by LaureltheQueen
Good luck?
Posted: Tue Nov 29, 2005 6:25 am
by douglas vincent
I will make sure all the male hookers we hire are extra nice to you!
See you tommorrow!
Posted: Tue Nov 29, 2005 6:51 am
by entirelyturbo
douglas vincent wrote:I will make sure all the male hookers we hire are extra nice to you!
See you tommorrow!
HAHAHAHA :lol: :lol:
I know how it feels Josh...
My Legacy is doing the following:
- Being very reluctant to start; I think it's the fuel pump... I'm going to do a fuel-pressure test tomorrow in fact.
- Tapping its valves at idle. I think the oil pump needs resealing/rebuilding.
- Springs are moving around inside the struts. I have fresh new GR2's on old and abused stock springs, so they're not holding enough weight.
- My left rear door lock is so screwed up that the inside handle will jam open.
- The stuff that's already been wrong with it for a while: Unfinished and non-functional R134 A/C conversion, HVAC controls acting up, car looking like ass...
And to think I just dumped nearly two thousand fucking dollars into this car to fix the wheel bearings and all that other shit that went along with it...
It's not an issue of not knowing what to do or not being able to do it, it's the issue of not having the money or the time...
Posted: Tue Nov 29, 2005 8:10 am
by BAC5.2
Josh, I replied to your exhaust thread. I hope I can be of some help to you.
I totally forgot, did you still need the transmission specs?
Posted: Tue Nov 29, 2005 8:14 am
by 555BCTurbo
I am in a shitty mood as well...since my fuckin Legacy wont start!!!
Posted: Tue Nov 29, 2005 8:50 am
by BAC5.2
Not starting is an easy problem to fix. I've got to rebuild the tranny in my 94, pull the engine and drivetrain out of the 91, and replace the clutch in the Forester.
Just put a smile on your face, because at the end of the day, you wouldn't sell your baby, would ya?
Posted: Tue Nov 29, 2005 3:23 pm
by legacy92ej22t
My car's been off the road 9 months, out of the past 18. Currently sitting with blown tranny and might be looking at a part out.
Things could be worse.
Posted: Tue Nov 29, 2005 5:35 pm
by greg donovan
it took me 45 minutes to chisel 1/8-1/4 inch of ice off of my car and another 45 minutes to chisel free my wife's car. it was windy and blowing frozen bits of razor sharp ice in my face.
Posted: Tue Nov 29, 2005 6:43 pm
by Binford
greg donovan wrote:it took me 45 minutes to chisel 1/8-1/4 inch of ice off of my car and another 45 minutes to chisel free my wife's car. it was windy and blowing frozen bits of razor sharp ice in my face.
Ditto, except that was yesterday for me at work. Isn't winter fun?
Things will work out for ya, man, we all know it will. 8)
Posted: Tue Nov 29, 2005 7:27 pm
by skid542
Passing the virtual pitcher of cold fresh beer or whatever happens to be your taste....
It'll work out man, just hang in there and don't give up. The good things in life take work, albeit excessively sometimes.
Posted: Tue Nov 29, 2005 7:29 pm
by LaureltheQueen
My car runs good. :)
the only mechanical "problem" that I have is a small exhaust leak between 0 and 5 psi on moderate throttle between the dp and mp. I imagine coating the doughnut gasket in rtv copper and hammering at the flanges a bit will fix the problem. I'm just too lazy to fix it. :)
Posted: Tue Nov 29, 2005 7:35 pm
by magicmike
in response to your cable modem. mine was doing that for one day and then it finally took a dump. the guy on the phone for service told me the whole unit went bad. I'd look into replacing it. sorry :(
Posted: Tue Nov 29, 2005 9:43 pm
by legacy92ej22t
The Motorolla Surfboards are cheap. Like $20 after rebates or even less on ebay.
Posted: Wed Nov 30, 2005 3:27 am
by JasonGrahn
If you'll be up here this weekend, you can help me move, then we'll get drunk and make a good time in bellingham! wooooo
Posted: Wed Nov 30, 2005 5:15 am
by subawhatsubawho
Its just one of those days
When you don't wanna wake up
Everything is fucked
Everybody sux
You don't really know why
But want justify
Rippin' someone's head off
No human contact
And if you interact
Your life is on contract
Your best bet is to stay away motherfucker
It's just one of those days!!
[chorus]
Its all about the he says she says bullshit
I think you better quit
Lettin' shit slip
Or you'll be leavin with a fat lip
I think you better quit talkin that shit
(Punk, so come and get it)
Feelin' like a freight train
First one to complain
Leaves with a blood stain
Damn right I'm a maniac
You better watch your back
Cuz I'm fuckin' up your program
And if your stuck up
You just lucked up
Next in line to get fucked up
Its just one of those days!!
[chorus]
I feel like shit
My suggestion is to keep your distance cuz right now im dangerous
We've all felt like shit
And been treated like shit
All those motherfuckers that want to step up
I hope you know I pack a chain saw
I'll skin your ass raw
And if my day keeps goin' this way I just might break somethin' tonight...
And if my day keeps goin' this way I just might break your fuckin' face tonight!!
Give me somethin' to break
How bout your fuckin' face
I hope you know I pack a chain saw, what!!...
I was supposed to be in Orlando tonight doing a very pricey computer job but the fucking morons didn't bother to read the memo that told them they needed to back up their files to a networked drive! I was in O-town last night for the same job with a different company. Everything was going fine...computers were loading the new image....3/4 way thru ....BLUE SCREEN OF DEATH!!! Reboot...3/4 way thru...BLUE SCREEN!!! I call tech support and they realize the script is fucked!!! They patch the script and all goes well. It's all good because I got paid to sit and watch TV and eat Krystal burgers. I will be in Orlando all next week on the same project.
On another note I saw MAAAAAADDDD gen1 legacys in O-town yesterday and today!!
Subyluvr...have you seen that SWEET white STi on East 50 next to Maryland fried chicen? That thing is soooooo hot!! Valencia traffic still sucks!!
Posted: Wed Nov 30, 2005 12:50 pm
by Manarius
subawhatsubawho wrote:Valencia traffic still sucks!!
Tell me about it. When I was down there 8 years ago...I remember that specifically.
Posted: Wed Nov 30, 2005 6:43 pm
by entirelyturbo
subawhatsubawho wrote:Subyluvr...have you seen that SWEET white STi on East 50 next to Maryland fried chicen? That thing is soooooo hot!! Valencia traffic still sucks!!
That's out past Alafaya isn't it? Usually the only reason I'm out that far east in the first place is to go to UCF, and I stay on University when I do...
What does it look like? I might know the owner...
Posted: Wed Nov 30, 2005 7:55 pm
by subawhatsubawho
It's just east of VCC on 50. It's at a used car lot next to the maryland fried chicken.
Below is a link to the map.
small link that doesn't screw up page width (aka: map)
edited by Legacy777 to fix page width
Posted: Fri Dec 02, 2005 4:58 am
BAC5.2 wrote:Josh, I replied to your exhaust thread. I hope I can be of some help to you.
Saw your thread. I'll definitely try out your suggestions.
I forgot, what transmission specs was I asking for???
Posted: Fri Dec 02, 2005 5:00 am
magicmike wrote:in response to your cable modem. mine was doing that for one day and then it finally took a dump. the guy on the phone for service told me the whole unit went bad. I'd look into replacing it. sorry :(
I swapped out the modem this afternoon when I got back. It still had a little hissy fit tonight....however not as regular. So I don't know what the fuck is going on.
I'll keep bitching at TW ;)
Posted: Fri Dec 02, 2005 5:02 am
JasonGrahn wrote:If you'll be up here this weekend, you can help me move, then we'll get drunk and make a good time in bellingham! wooooo
I wish....was in PDX just for a short 2-day trip.
Where you movin to now? I thought you already lived close to town. We'll definitely have to do some drinking one of the times I'm up there and walk (stumble) back home.
Posted: Fri Dec 02, 2005 5:05 am
Thanks guys (& Laurel) for the comments.
I've simmered down......still not happy, but definitely more calm then I was when I posted this.
Posted: Fri Dec 02, 2005 8:52 am
by JasonGrahn
moved to a different part of town now. No bars so far in stubling distance. Have to recon.
Posted: Fri Dec 02, 2005 4:12 pm
by subawhatsubawho
I was in a bbaaaaaddd mood last night something fierce. My stupid credit card company keeps F'ing up my Paypal transfers by not moving the money to my CC. I call the CC company and they give me the run around and blah blah blah...
So I chuck my keyboard across the room and ALLLLL the keys come off. I spent about 2 hours looking for all the stupid things so my kids wouldn't find them and put them in their mouth. Then I was extra pissed because I needed a keyboard too. So I stroll down to wal-mart this morning to pick one up. The damn CC company put a security hold on my funds!!! AAAGGGHHHH!!!! DEATH TO CC COMPANY!!!
