EJ20 TT
Posted: Tue Dec 06, 2005 2:57 am
by tomdewing
Not sure if this is the right place or if anyone can help, was sent over here by someone on the NASIOC forums.
I have a JDM EJ20h TT from a JDM 1996 Legacy that I am trying to put in a hovercraft which I am building. http://www.tomdewing.co.uk (the UH-18SPW)
The problem is it was not removed very gently, all the vacuum hoses have been cut and the vacuum resivoir is missing.
I am in need of some diagrams as I dont know where to start, I need a wiring diagram and a vacuum routing diagram. Does anyone know where I can source these?
Subaru were little help with their STIS site as they claim that the EJ22 was never fitted to the legacy, however I have a VIN plate that proves otherwise!
Any help you can offer would be greatly appriciated as this will start to be a problem shortly!
Thanks.
Posted: Tue Dec 06, 2005 3:03 am
by dzx
There is a sticky at the top of the intake section with vacuum diagrams.
Posted: Tue Dec 06, 2005 4:44 am
by tomdewing
The problem is that is for the single turbo setup and this is the 2 stage twin turbo, the setups are completely different and im not sure how they connect!
