Where did the frickin' gas go?
Posted: Wed Dec 14, 2005 7:58 pm
by supernoob
After swapping gas tanks during my FWD to AWD swap, when I went to buy gas for the first time, I put in about $20 worth. The needle climbed up to about the 2/3 mark as expected. But after a little driving, it started going up and down slowly. Later in the day, it settled at around 1/4 tank. I thought the guage was just goofy, but when I went to top it off, it took another 11 or so gallons. No leaks anywhere. No smell inside or out. Is there just a dead spot in the tank due to the 'saddlebag' shaped AWD tank?
Stephen
Posted: Thu Dec 15, 2005 12:03 am
by rallysam
Do you put a jet pump from an AWD in the other side of the saddle bag?
Posted: Thu Dec 15, 2005 1:22 am
by supernoob
[quote="rallysam"]Do you put a jet pump from an AWD in the other side of the saddle bag?[/quote]
I put the whole AWD tank and pump(s) and swapped out the harness as well. The two fillups since have been normal.
Posted: Thu Dec 15, 2005 1:38 am
by BAC5.2
Sometimes the Jet Pump goes bad.
Posted: Thu Dec 15, 2005 3:11 am
The jet pump really can't go bad.
It's nothing but a venturi pump. The piping for the jet pump tees into the return line coming from the engine. As the fuel flows by the opening it creates suction, which in turns draws fuel from the other side of the tank.
I suppose something could get lodged in the piping causing it not to work, but that's about all I can think of.
here's a pic
http://www.main.experiencetherave.com:8 ... P_5286.JPG
Posted: Thu Dec 15, 2005 7:24 pm
by BAC5.2
I remember someone having fueling issues, and swapping the fuel pump assembly (using the same fuel pump) solved the problem.
Might have been a coincidence.
Posted: Sat Dec 17, 2005 9:42 pm
by supernoob
Well, last night the needle dove from 1/2 to 1/4 at a stoplight(on level ground) and then slowly returned to 1/2. But there is still about 6 gallons unaccounted for from the first fillup after the swap.
