Revving in neutral
Splinter
Revving in neutral
Post by Splinter »
Is it bad for your engine?
As a temporary cure for my rough idle, I was gonna just keep the throttle partly open at stops
no
Legacy_2.5GT
Post by Legacy_2.5GT »
Sounds like a throttle positions sensor. Which from personal experience you will probably only find at the dealer. I had the same problem with my 97 Legacy.
Legacy_2.5GT
Now that I think about it, try changing your idle air control valve first that is more likely to cause the reving.
Splinter
Post by Splinter »
No the problem is that my stereo is causing my ignition to misfire due to low voltage.
douglas vincent
Post by douglas vincent »
Stereo = bad
exhaust rumble = good
Splinter
Post by Splinter »
douglas vincent wrote:Stereo = bad
Cruising down the highway in drive isnt that exciting to listen to.
