Map sensor wire in?
Posted: Sun Dec 18, 2005 10:36 am
So I picked up a 3 wire map sensor at the junkyard today. I have no clue if it is a good one or not ie 1 bar, 2 bar ,3 bar.
But.... I just want to read a amp out of it for now.
Should I wire in one wire ground, one wire tapped into a 5v source and one wire signal? I am pretty sure which wire to use for each, but does this make sense?
