i cant tell of its engine or turbo, i would put money on turbo since the car has 187K on it.
but at 1-3psi, 2psi mostly, you can hear it, its like a rattle, but i dunno really, im worried that the bushings are toast and it has alot of shaft play so its wobbling around against the housing.
is there any way to check it ad find out what it is.
also if it is the turbo, can i swap on a slightly larger turbo, nothing huge, just a equal sizws one or slightly larger, i need to try to keep the car so i get decent milage/drivability out of it.
Weird Sound
Weird Sound
1986 GL wagon
EJ'ed and Lifted
1986 GL wagon
EJ'ed and Lifted
