wrx downpipe?
Posted: Wed Dec 21, 2005 6:42 am
by poseidon1787
ok i am gettting ready for an ej20t swap, is it true that i need a wrx downpipe and crossmember??? or do i just need the motor and the harness?
Posted: Wed Dec 21, 2005 4:17 pm
by Matt Monson
http://bbs.legacycentral.org/viewtopic. ... om+exhaust
That's my old thread from the exhaust forum. You can either use a Legacy turbo downpipe, or use a WRX downpipe and modify your midpipe accordingly...
And you definitely need the crossmember. The exhaust plumbing won't clear the NA crossmember...
Also, you need the ECU, in addition to the motor and harness. And all of the intake plumbing, MAF sensor, and related boost sensors and solenoids...
