AWIC Pump wiring
Posted: Thu Dec 22, 2005 12:39 am
by georryan
I want to wire my intercooler pump into the ignition. Basically I'm thinking of only having it run when the ignition is turned on, and it will still be off on the accessories position. Where is the best place to do that?
I was thinking of putting a switch into the line as well in case I want to disable the pump for any particular reason.
Where did you wire your pump Josh?
Posted: Thu Dec 22, 2005 9:24 pm
I haven't wired mine up, but I'll probably do the ignition as well. I may tie into an ignitoin lead in the electrical stuff behind the battery (still not sure yet) or just run a line from in the cabin.
