Turbo temp calculator
Posted: Mon Jan 09, 2006 7:40 pm
I have no idea how accurate this is.
Im assuming its at least good enough for an order of magnitude[/url]
A forum for 89-94 BC-BF(BJ) Legacy Owners and Fans
https://bbs.legacycentral.org/
that's because it's so negligible that it's not even a concern. Air gains almost no heat energy as a result of the turbo's proximity to the exhaust, the air moves to quickly and the turbo doesn't have enough surface area to make a measurable difference. This is a common misconception among people. It’s often thought that turbos need intercoolers because they are run off the exhaust. They need intercoolers because the air is compressed and gains heat energy in this manner. Since superchargers (roots types at least) generally don’t have intercoolers, people think it’s a problem only turbo have. The reality is that superchargers need an intercooler just as much as a turbo does. Even more so at high boost levels as roots type superchargers tend to only be efficient at PRs less than 2.Splinter wrote:The calculator doesnt account for the heat of the turbo produced by the exhaust gasses, this is why I dont think its accurate.
