Hayne's manual says to drain the oil from the crankcase before removing the oil pump. Is this necessary? This coming weekend I will be replacing my leaking water pump and a list of other parts while I am in there. Including checking the oil pump backing plate fasteners and replacing its o-ring. Don't want to drain the oil, unless it will make a big mess when removing the oil pump, because I will have the oil changed when the job is complete. Searched oil pump removal and got lots of good info, but nothing said about draining the oil.
