Sleeve SPUN?!?!*Pics Added*
Posted: Tue Jan 10, 2006 8:15 am
by napphappy
So I tore into a EJ22t that I bought for parts. The seller said it had been overheated. Had no idea what to expect.
I get the left side front wrist pin accses plug out and :shock: the iron sleeve has rotated so that it is mostly blocking the hole.
I have pics I will post later.
Has anyone ever seen or heard of this before?
Also part of the block deck on #3 had melted away.
Posted: Wed Jan 11, 2006 4:52 am
by evolutionmovement
That's uh ... not good.
I'd say that overheated a little bit.
Posted: Wed Jan 11, 2006 4:58 am
by dzx
I've never heard of that happening.
Posted: Wed Jan 11, 2006 5:11 am
Sounds like that block is toast.
Posted: Wed Jan 11, 2006 5:21 am
by scuzzy
I had the return hose from my IAC break off the coolant return to the radiator and spew coolant out of my engine (took it awhile to run low, took me awhile to notice it)
the block got hot (I drove it till it approached Hot, then stopped) but I can't imagine what kind of heat that thing suffered.
Posted: Wed Jan 11, 2006 5:23 am
by dzx
I overheated my block a couple times due to a shitty connection in the radiator fans before i figured out what was wrong. Then my radiator blew the end tanks off.
I haven't had any problems with it though, and that was about 5 months ago. knock on wood...
